Buying new 6.2 truck, need axle ratio opinions for towing!
#31
I've been wondering about the difference between the two ratios for a while. fficeffice" /><O></O>
My question is: With the close gears in a 6 speed tranny is there really any difference in RPM between the 3.73's pulling in a lower gear compared to the 4.30's in a higher gear at the same mph? And if there isn’t, wouldn't the better mpg for the other 80% regular driving be the better scenario?
#32
#33
While towing I do notice I am very seldom in 6th gear. Most of the time it's in 5th unless I get some flat land and doing at least 60 mph on the highway. So the truck will compensate for not having the smaller gear. I would like to have the 4.30 while towing but other then that I can do without it and have no regrets on getting the 3.73.
#34
#35
Newbie here that's been driving a Chevy LB7 2500 for 9 yrs thinking of changing to Ford SD 6.2L F-250 or 350. The only difference in the Chevy 2500 vs 3500 are the shocks and number of leafs in the rear springs. Axles, brakes, hubs (excluding dually), etc. are the same.
I'm wondering if F250 and F350 have same axles, brakes, etc. If they do, and I order a F250 with the 471 Camper Pkg, what am I missing out on?
Thanks in advance for the info. Last Ford I drove was a 92 Ranger that almost beat me to death on I-55 every day.
#36
YES...the F250 and F350 (non-dually) have the same exact setup...brakes, axles, etc. The F350 is taller out back with a 4" block...which gives it the ability to sag more...and more GVWR.
Good luck with it...
biz
#37
Thanks Biz4. I suspected they were the same, but could not find confirmation with build parts or from Ford Corp. info. Even with the Camper Pkg on the F250, the F350 would still have the block in addition; thus, increased GVWR somewhat. It's hard for me to equate $990 (increase cost in F350 vs F250) when the Camper Pkg is $160 accomplishing almost the same capability.
I think you have answered my question and I do appreciate the information.
R.K.
R.K.
#38
note: if you order with the camper package ford wont let you get rims bigger than 18" I think it is cause of the stabilizer bar...
Ron_CNY
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
21
02-04-2022 06:21 PM
titansfan
05-23-2004 07:15 AM
bcf
02-22-2004 06:51 PM
