7000# trailer - use overdrive or not?
I doubt that 5.4 will hold overdrive. If it does, you'll be lugging the **** out of it. My V10 would hold O/D when towing 9k on level highway @ 65, but would only get about 8 mpg. Same trip on the return netted me just over 11, same speed, O/D locked off, with another 1500 lbs added.
Yea it would do it, but it was lugging it. Gassers like to spin a lil more when loaded, and are more efficient that way too.
In my 2000 F250 2wd, 5.4 with 4.10 limited slip,I towed trailers in excess of 10,000 up to 20,000+ and I rarely turned off the overdrive, I would rarely use the tow/haul mode, the truck has over 242,000 miles on it and I never had any drivetrain issues with the truck.
Somoene told me the newer trucks tow/haul mode change the shift points and use the engine to help braking.
If it is like my 2012, you should be able to lock out any gear you want to, using the +/- on the shifter cloumn.
It was my understanding there were very few changes between to 2011 and 2012, but the engine and transmission as well as the running gear is the same.
In my 2000 F250 I rarely turned off the overdrive and I towed a lot of weight, I am in Florida so it is pretty flat, we do have the ocassional hill though.
I have the same truck only with a 6.8 v-10, I have never turned off the overdrive. And I tow a construction trailer frequently.
Usually critical in fuel saving while towing is having converter lock engaged.
When you pull on OD with convertor slipping -lot of engine energy goes into mixing the fluid, while turning OF off might get you converter lock on lower gear and fuel savings.
I don't know if your transmission has converter lock on lower gear, so that would be the first thing to check.
There is no worry about extra engine stress while on OD >>> if the engine can drive it, it can take it.
Other thing is listening to the engine fan. The fan takes lot of energy and drops mpg quite drastically. Sometimes lowering the speed by couple of miles keeps the engine colder and prevents the fan from coming on.
