Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Exterior Guides
- How to Change Your Headlight Bulb
Step by step instructions for do-it-yourself repairs
Grill Removal & Headlight Replacement How-To
I had a hell of a time getting the bottom grill spring clips released because the 2012 Owner's Manual says to release them by going in from below. This worked with older F250s but not the newer ones. You have to go in from the top or side of the grill to release the spring clips.
I did a How-To for grill removal and headlight bulb replacement.
The How-To can be found here: F250 Grill
Pictures from the how-to:
On my 2011, i replaced the lights without removing the grill, the right side was pretty easy to get to, the left side was a bit trickier but i easily removed the airbox/coolant resivor out of the way and i was able to get my hand down there and replace the bulb. I had the whole job done in ten minutes.
Quarterwave
02-27-2018 08:03 PM
HIO Silver
60
03-13-2016 11:38 AM
