Bio Diesel/Oil Selection
Old 07-25-2012, 09:17 AM
Olds69442's Avatar
Olds69442
Olds69442 is offline
I live in Pennsylvania and all diesel is supposed to have 2% bio in it. Does that mean I should be running the ford oil recommendations for biodiesel?
Old 07-25-2012, 10:00 AM
BeatMarti's Avatar
BeatMarti
BeatMarti is offline
Do you mean 5K oil changes and 10K fuel filter changes? - Well, I do that regardless of what type of fuel I purchase. If you travel a lot/far, there is no way to tell anyway. I also use the recommended dose of Opti-Lube summer blend with every tank.
Old 07-25-2012, 03:05 PM
Olds69442's Avatar
Olds69442
I was refering to the oil weight. The filler cap read indicates a different weight oil if using Bio. I am not sure using 2% Bio means that I should switch from the 10W-30.
Old 07-25-2012, 05:42 PM
gmhorse's Avatar
gmhorse
gmhorse is offline
Straight from the Diesel Supplement Manual
10W-30 (normal usage)
1For severe duty usage, use SAE 5W-40 API CJ-4.
2For biodiesel (grades B6-B20) usage, use SAE 5W-40 or SAE
15W-40 API CJ-4.
Looks like that is only for B6 - B20 Bio-diesel
If you are using B2 then I say stick with the 10w-30 unless you are in some extreme cold.
Old 07-25-2012, 05:56 PM
BeatMarti's Avatar
BeatMarti
There is no way I would use anything but 5-40 API CJ-4 oil unless I'd live in a southern (hot climate) area where I would go for 15-40 API CJ-4.
Old 07-25-2012, 07:15 PM
slowmans's Avatar
slowmans
slowmans is offline
I run B-20 in my 6.4 and also run 5w-40 year round. My last UOA was excellent!
Old 07-25-2012, 08:30 PM
Olds69442's Avatar
Olds69442
Thanks for the feedback. Much appreciated
hookedondiesel
04-26-2012 07:07 PM
TheTowingCowboy
Bio-diesel, Propane & Alternative Diesel Engine Fuels
07-01-2010 04:39 PM
jle70
21
05-17-2007 04:00 PM
timeline
15
04-09-2005 09:37 AM
motobub
Oil & Lubrication
03-13-2003 05:21 PM
Quick Reply: Bio Diesel/Oil Selection
