need help with my 1989 for f250 4x4
on
If you don't want the dome light to ever come on ever then take open truck. There is a little button like thing that if you press it should turn off the light. If you disconect the light won't ever come on. My ranch which is a 1989 Ford F250 4x4 has them disconnected so I can keep the door wide open without draining battery or a buzzer when my key is in the ignition because of the fact the key is jammed into the ignition.
Trav
Trav
