11-24-2014, 05:56 PM
See related guides and technical advice from our community experts:
Browse all:
Brake Guides
Help me find why my ABS light is on.
12-28-2011, 02:03 AM
Carpenter Local 745
I finally got my new IAC installed, now my ABS light is on.
I have not checked anything so far, but has anyone
Solved their ABS warning light problems?
12-29-2011, 10:11 AM
on
Did you try clearing the codes(disconnect the Bat for 10)?
it could just be a fluke, double check the connections from the sensors to the abs module(should be in the engine comp on the inner wheel wells).
12-29-2011, 10:19 AM
sounds sensor related. remove the sensor on top of your rear diff and clean it off and reinstall it. if that doesnt work pull codes.
is your speedo working
12-29-2011, 11:00 AM
on
Quote:
Originally Posted by
Kemicalburns
i remove and clean mine probably once a year when the VSS code comes up. easy way to start eliminating possibilities
12-29-2011, 01:10 PM
Carpenter Local 745
12-29-2011, 02:02 PM
on
that would rule out the rear abs sensor,. Did you try to clear the code?
12-30-2011, 03:14 AM
Carpenter Local 745
Big Greenie
1997-2006 Expedition & Navigator
10-06-2010 01:27 PM
billcollector
02-05-2010 02:33 PM
Boostmonkey
12-20-2008 05:05 PM
luvemhot
15
02-07-2008 04:10 PM
the4by4freek
1997 - 2003 F150
01-25-2004 04:43 PM
1994 ,
1996 ,
2003 ,
96 ,
abs ,
antilock ,
bronco ,
clear ,
code ,
f150 ,
ford ,
light ,
on ,
sensor ,
truck ,
trucks
