4x4 donor chassis for a Ranchero?
Has anyone done or know of this type "marriage"?
I posted this on the Ranchero forum but got no responses (not many hits there).
I want to use a donor 73-79 short bed 4wd and put it under a 59 Ranchero.
The Ranchero wb = 118", the 79 short bed wb = 117".
I would lift it, if neccessary for clearances. Would the 1 inch difference in wheelbase be a problem? What other issuses would I riun into? Is this a pipedream?
Skip
Skip
on
I am a true believer in anything is possible...if you have the time, money, equipment, working space, fabrication skills and enough cold "wobbly pop".
The only real advice I can give you is to measure, measure and measure again. Then start trial fitting and fabricating. I do not think it would bolt directly on but you never know
"there is one right here in town. he put the body on a bronco frame"
Big A,
Is it a 59 Ranchero? If so, any chance of getting the guys' phone # or email address so I could pick his brain?
This is a real bad itch I got and would really like to explore it.
Skip
Big A,
Skip
