no power to pcm - Ford Truck Enthusiasts Forums
no power to pcm
Old 12-26-2011, 01:03 PM
speedbanger90
speedbanger90 is offline
speedbanger90 is starting off with a positive reputation.
no power to pcm
#22 fuse and relay are good still no power any deas?
Old 12-26-2011, 03:34 PM
Hussler's Avatar
Hussler
Hussler is online now
Hussler is a splendid one to beholdHussler is a splendid one to beholdHussler is a splendid one to beholdHussler is a splendid one to beholdHussler is a splendid one to beholdHussler is a splendid one to beholdHussler is a splendid one to behold
Well, fuse #22 is the PCM "relay" fuse which is usually the culprit. The actual power fuse that protect the PCM is fuse #9, 20 amp so check that one.
Old 12-26-2011, 05:41 PM
speedbanger90
checked fuse #9 and it is good could the pcm fry for no reason going down the road? it died on me and #22 was blown i replaced it and havent been able to get a wts light and it wont start since i have checked all the fuses and the relay but i still cant get power to the glow plugs and it still wont start any suggestions would be appreciated
Old 12-26-2011, 06:06 PM
fordpride's Avatar
fordpride
fordpride is offline
fordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant future
Unplug the fuel bowl heater and Check fuse #22 again
Old 12-26-2011, 06:34 PM
F350-6's Avatar
F350-6
F350-6 is offline
F350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputation
Got any codes? Got a chip in the truck?
Old 12-26-2011, 07:01 PM
rideracelivemx7's Avatar
rideracelivemx7
rideracelivemx7 is offline
rideracelivemx7 is starting off with a positive reputation.
Action4478
Action4478 is offline
Action4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputation
If you have a chip & it fell out going down the road , it could well be an issue with the PCM .. Does the check engine light come on & stay on (kind of dim) ?
Old 12-26-2011, 09:46 PM
DIYMechanic's Avatar
DIYMechanic
DIYMechanic is offline
DIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to behold
He has already done some of this. Here is a link to his other thread.
https://www.ford-trucks.com/forums/1...ter-dying.html
I am wondering if the PCM isn't fried. Has it rained lately where you are? You don't happen to have noticed water leaking in through the driver side lower corner of the windshield have you?
Only other thing you can try is to unbolt the wiring connector from the PCM and see how the connections look and probe right there for power.
Old 12-27-2011, 08:45 PM
speedbanger90
it was raining the day it quit but the windsheild doesnt leak i have been trying to get a wiring diagram from ford for 2 days to find out what wire going into the pcm is the power i really need to get this truck running so if anyone knows what wire it is i would appreciate it
Old 12-28-2011, 09:16 AM
DIYMechanic
Try this one:
And here is the wiring legend:
According to the diagram, pin 71 should be a Red wire and that should be the power input to the PCM.
Hopefully this helps.
Old 12-28-2011, 10:00 PM
speedbanger90
I got her runnin tonight after almost a week the powerwire going to the pcm had rotted in two good ol illinois roadsalt eats em up thanks for all the help guys I really appreciate it
Old 12-29-2011, 09:21 AM
DIYMechanic
Glad you got it going again. Gotta love road salt. Although I would take the salt over the brine solution the state has started using on the interstates around here. Nasty stuff.
delval
1997-2006 Expedition & Navigator
16
08-06-2017 11:21 AM
jason
04-01-2017 12:49 PM
Sherman Torres
Electrical Systems/Wiring
11-21-2015 05:27 PM
bicounty
39
02-24-2015 10:41 PM
otto
03-06-2001 07:34 PM
Quick Reply: no power to pcm
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
