mounting a snow plow on a 54'
a few of you here use your trucks plowing ,and I have just found a front mount style plow for my 54 M-H ..is there anything I should watch for when mounting it ?does the frame need to be reinforced ?..is any part designed to fail to protect the truck in a curb-hit or other impact ?I see newer plows hav foot on them to give clearance off the road ..should I add this to the set-up ??.I am not going out to make money ..i clear our street and my mom's driveway when we get snow ..so it's not a big unit ..any advice ?? suggestions ?? warning's ??thanks
Most plows are hinged to fold down if you hit something like a curb. That's why they have those big coil springs on them. There are a few that are spring loaded so that just the cutting edge folds back in a hard hit. All plows come with shoes that hold them up from the road, most plow men remove them so that they get a good scrape to the pavement. That's why you'll see a lot of well used plows that have crooked cutting edges from all that use.
on
for what its worth here is my advice. do NOT mount a plow on the front of your 54 F350 MH AWD. do you know anyone else that has this truck? sell me your truck and buy a pos chivy plow truck. i will trade you a pos plow truck for your MH if you want to push snow. no need to worry about the cost of a plow or how to mount it, whats the cost of your t-case or front axle? whats the price for a twisted frame? thats the question you should ask yourself. but thats my 2 cents.
Ken - I hauled an F-3 M-H home once that had been used to plow. The front frame had been bent, fractured, and ranch welded. And the transfer case had been grenaded and replaced with a Jeep or some other donor case. I've held on to the chassis thinking I can fix the frame abuse, and hopefully find a correct transfer case. Knowing what you went through to find your replacement front axle shafts, I wouldn't push my luck if I was you. Stu
Don't Do It!
Thundersnow is right. Why risk a classic truck when there's plenty of later-model 4x4s that are better set up for plowing? I grew up in Massachusetts and we all knew that plowing with a truck ruined it, no matter how "easy" you were on it. Save your sweetheart, kill a Chebby.
Tim's got a pretty kick @3S Plow truck if you ask me. but he gets lots of snow. I guess I didn't realize the Island got much in the way of snow?
Yes plow trucks get pretty beat up no matter, one thing I could never quite understand is people putting plows on front of the little Willey's and Ford army jeeps. I can't imagine they were all that great at pushing any snow being so short and really not very heavy. plus the salt has eaten them all up.
on a side note my Stepdad had a 56 F100 when I was a kid in the Black Hills, we lived about 10 miles or so past the last county snow removal/school bus turnaround up in a little cabin (part of an old snowmobile lodge.) and he mounted a huge V-nose plow on his 56 and would plow his way out in the morning and plow on the way home as needed. I was to young to remember how he lowered it or raised it but this was a working truck for sure! he would also plow off the little pond up there for ice skating on etc. Wish I had a picture.
yep 2 wheel drive truck- you don't need 4x4 if you can drive like a bat out of hell! just keep going-never slow down...
Up here I've seen snow plows mounted on almost every kind of vehicle.....including 2wd trucks. So it is possible.....
Would likely be hard to steer though, as said. Around here guys keep an old beater truck just for plowing, since they take a lot of abuse. I have an old Farmall tractor to plow with...
This is what i do so the advise, an 8ft Fisher will do fine on an F5 for
your needs they are all around, of course you will have to face the
pulley & pump mounting problems. The fastest way is to go electo/hydraulic
providing you have 12Vt neg ground. Dont worry about power steering.
Only warning is, dont be an animal, thats the enemy. My route takes
5hrs usually has to be done twice. I soak underneaths with diesel fuel.
Years ago got rid of the heaters and I put 1973-79 heater boxes that
give wicked defrosters. My trucks are hired town trucks, so we have a
total of 12 and 3 pickups. What I do is before snow season I take a
ride of my route checking any changes > big threat, manholes new
curbings, etc. General highway plowing speed around 15-18MPH anything
more you get it right over the windshield and everybody knows that
1953 to 56 wipers totally s**k. No snow yet , our biggest problem is
no fuel nobodys open after midnight. look in my garage for the one
with the electric fisher plow works slick.
OK .one more dumb idea in the fire ..I guess the snow plow can be yard art ..the way it has been raining here I won't get to play with it much anyhow ..but it would scare the crap out anyone seeing the old girl loaded with a blade out front !! it was a great Idea ..well at least I thought it was ..thank's for the warnings ...
When I was a kid my dad rigged up a plow on the truck the eventually became my F-2. I'm pretty sure the plow predated the truck, I think it must have come off a Model AA truck. It had a X cross frame and the plow blade had a semi circle braket that you used to change the angle of the blade. You set it at the angle you want and then inserted a pin to fix it. The back of the X frame had two doughnuts. There was a pipe welded to the bottom of the front bumper and you'd line the doughnuts on either side of the pipe, insert a smaller, longer pipe inside and used the pipe to pivot the plow up and down. At the front left corner of the X frame there was double piece of angle iron aobut 6-7 high with a loop at the top. There was a rope tied through the loop and strung through the driver's door, over the top hinge. You raised and lowered the plow by pulling the rope and slamming the door on it to keep the plow up. Open the door and the plow would drop. I remember him plowing his gas station parking lot and our home driveway with this rig.
wow ! that's neet ..bigger then my truck prettyer (?) too!..we get 3 inches of snow and the city shut's down right now the rain is so heavy you can't see the end of the street ...and that's only a few hundred feet ..I amazes me how much experiance is here ,practical and knowagable that you all share without your help i would have done a lot of damage to my truck or just ruined it I may not agree with everything you say or share ..but it does stick ,,I do listen ..an I do thank you all for all your help
