V10 Runs Rough at 1500-2000 RPMs
I have had problems with the engine running rough for 6 months now and my gas mileage sucks. I put new spark plugs and I also bought one coil and slowly moved it to each cylinder to see if it made a difference. No difference.
I also had a vent issue where it would only blow defrost. Then my auto hubs wouldn't lock in. I sprayed all the lines down and cut a hose and reattached it where it was warn. That hose is the one that goes to the passenger side engine and has a coolant hose running into it. The circle metal piece seems to be just sitting in the engine. Now it is not running rough like it used to at idle. My hubs and vents work now as well. My exhaust doesn't smell any more ether. (IM GUESSING it will be temporary).
The one problem that didn't go away was the rough running at 1500-2000. I do still here a hissing sound coming from the top of the engine but i cant pin point it. It sounds like it is coming from the IAC.
Any suggestions?
Any suggestions?
