Convert to 4x4
Convert to 4x4
I have a 1983 F250 (six cylinder, four spd.) that the body and box are shot on. I have found a fairly nice 1986F250 2wd with 460 auto. tans. I know I would likely need a different transmission/transfer case if I wanted to stay with automatic, and if I wanted to go with 4 spd. would need different bell housing and clutch. Any suggestions? My main concern is the front end.....how hard is it to switch to 4x4?
I am no expert, but the easiest would be to take the cab and box from the 86 and put them on the 83. If you want the 460 with the 4 speed, yes, you will need a big block bell housing, with big block engine perches, and (I think) new clutch & flywheel. I don't know if 2wd autos had the same bolt pattern for putting t-cases on. Converting to 4x4 is a lot of work, again, thats not my strong suit.
Swapping the bed out is easy. Swapping the cab out is certainly more work than that, but fairly straightforward - although I haven't as yet done it but have pulled most of the components to allow me to do it.
Changing to a 460 from a 6 is going to require all the things 4x484150 said. So, I vote with him - put the box and cab on the '83 4x4 and run the 6.
If you start pulling bolts on the bed, cab, or wherever, I recommend using a torch to free the nuts up. I pulled all the bed bolts without having any problems by using a MAPP gas torch and heating the nuts for ~20 seconds. Some times I'd have to go back and heat it again since it would start to seize as it cooled.
And, that works on bumper bolts as well.
Smurf-Slayer
07-22-2007 02:39 PM
QUEBEN
01-03-2004 05:08 PM
