CA-SMOG question again - Page 2 - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 12-27-2011, 04:39 PM
bens170
bens170 is offline
bens170 is gaining momentum as a positive member of FTE.
The CARB EO listings and additional information can be found on the CARB website at
Aftermarket, Performance and Add-On Parts, or by calling CARB at (800) 242-4450. I hope this helps.
Ben
Old 12-27-2011, 10:00 PM
A/Ox4's Avatar
A/Ox4
A/Ox4 is online now
9 ECHO 1
A/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputation
Here are the two PDFs straight from CARB regarding the two above filters.
Stage 1:
http://arb.ca.gov/msprog/aftermkt/de...eo/D-550-4.pdf
Stage 2:
http://arb.ca.gov/msprog/aftermkt/de...eo/D-550-1.pdf
Old 09-09-2013, 02:25 PM
RallyMedik's Avatar
RallyMedik
RallyMedik is offline
Bandaid dude
RallyMedik is starting off with a positive reputation.
So, I am also due for my smog..I have a 99.5 F250. I don't believe it came stock with a Catalytic Converter, nor does it have an EGR. I do have a 4" Turbo back, Chip with stacked tuner and intake with carb #. Question is..Can I just roll in to have it smogged or do I have to take the Chip and tuner out??
Thanks in advance.
Old 09-09-2013, 02:46 PM
bens170
bens170 is offline
Rally Medik,
There should be a decal on the radiator support that will have information on it as to if it has a Catalytic Converter and EGR system or not. This part of the visual inspection. To the best of my knowledge you will have to remove your chip system that is attached to your OBD II plug. The emissions tester has to plug his system in and it goes from the shop computer directly to DMV. I hope this helps and good luck with your emissions test.
Old 09-09-2013, 02:56 PM
SultanGris's Avatar
SultanGris
SultanGris is offline
SultanGris is starting off with a positive reputation.
Most people I know in cali keep them registered in a different state with no BS smog tests to pass, also it tends to be much cheaper to register in other states.
Old 09-09-2013, 09:19 PM
Pickupmanx2's Avatar
Pickupmanx2
Pickupmanx2 is offline
Pickupmanx2 is a splendid one to beholdPickupmanx2 is a splendid one to beholdPickupmanx2 is a splendid one to beholdPickupmanx2 is a splendid one to beholdPickupmanx2 is a splendid one to beholdPickupmanx2 is a splendid one to beholdPickupmanx2 is a splendid one to behold
Having a "fleet" of trucks, my smog guys thing is that he should NOT SEE any sort of programmer, stack, or anything other than stock and EGT probe or the like. When my 02 had the Edge, I put it to stock and tucked it under dash.
Definitely check for the DPF or CAT sticker, and make sure it didn't have one BEFORE you go smog it. Not sure if there was a rhyme or reason the them, I have had 3 with a DPF, a late 99 and an 01 and my 96, my 02 Ex, my 01 F350 and my 02 F350 never had them.
Good Luck!
Thanks in advance.
Old 09-09-2013, 09:28 PM
senix's Avatar
senix
senix is offline
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
Good Luck!
DPF's did not come out till model year 2008.
Old 09-09-2013, 11:50 PM
A/Ox4's Avatar
A/Ox4
A/Ox4 is online now
9 ECHO 1
He probably meant cat, but he did say DPF. :POKE:
Old 09-10-2013, 12:08 AM
Yahiko's Avatar
Yahiko
Yahiko is online now
Yahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputation
Just more reasons to not take a job and move to Calf.
And I don't care how good and nice it is. One spoiled
potato in the bag of fries make it all taste bad.
Sean
Old 09-12-2013, 10:01 PM
Pickupmanx2
YUP,,,meant CAT, said dog,,,
nitro3421
N. California Chapter
02-17-2017 09:54 PM
wantahertzdonut
S. California Chapter
19
11-24-2015 08:38 PM
mototrig
08-28-2014 03:08 PM
CA-BRONCO
1978 - 1996 Big Bronco
06-20-2012 01:29 PM
hurley1718
1997-2006 Expedition & Navigator
18
02-27-2008 09:05 PM
Quick Reply: CA-SMOG question again
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
