FE 390 oil dipstick tube
I know this thread is old, but this is the best info I've found on dipsticks - Thank you NumberDummy, for all that you've done for me without knowing it. :-)
I just had my 360 rebuilt, and I broke the dipstick tube trying to get it out. I still have the dipstick - I can't find anything stamped on it but ADD & FULL (and an "M" about 2" up from FULL), but the measurements make it a
C7TZ-6750-B = 17.68" shield to full / 18.48" shield to add / 19.59" shield to end. 1967/74 F100/350
(Thank you NumberDummy)
Can anyone tell me what the part number is for the tube and/or where to get one?
I still have the dipstick, I can't find anything stamped on it but ADD & FULL (and an "M" about 2" up from FULL).
But the measurements make it a C7TZ-6750-B = 17.68" shield to full / 18.48" shield to add / 19.59" shield to end. 1967/74 F100/350.
C5AZ-6754-D .. Engine Oil Dipstick Tube / Obsolete
1965/70 F100/250 2WD & F350 352/360/390 // 1965/71 Galaxie/LTD 352/390 / 1966/70 Galaxie/LTD 428 / 1967/68 Thunderbird 428.
No Ford Dealer or obsolete parts vendor has any.
Will this work? I dunno.
D1TZ-6754-C .. Engine Oil Dipstick Tube / Obsolete
1971/74 F100/250 2WD & F350 360/390.
MILLER OBSOLETE PARTS in Binghamton NY has 1 = 607-722-5371.
NOS PARTS LTD in Waxahachie TX has 7 = 972-937-2201.
Yes, sorry, 69 F100 2WD.
What makes you suggest that particular alternative? (D1TZ-6754-C)
I'm finding a few online (C5AZ-6754), but they all say they are for a 289. LMC already shipped me one for a 302 (just to get me off of the phone when I was telling them I didn't think it would work, I think) that isn't even close.
I don't give a hoot what Fordification claims, here are the five dipsticks for 1965/76 F100/350 FE's.
C5AZ-6750-D = 17.55" shield to full / 18.59" shield to add / 19.59" shield to end.
1965 F100/350 2WD / 1965 F100 4WD / 1966 F250 4WD // 1965 Galaxie/LTD
C6TZ-6750-C = 19.09" shield to full / 19.57" shield to add / 22.32" shield to end.
1966/67 F100 4WD / 1968/74 F100/250 4WD / 1975 F100/250 4WD before serial number W00,001.
1967/74 F100/350 2WD / 1975 F100/350 2WD before serial number W00,001.
D5TZ-6750-A No specs listed / Marked D5TA-6750-CA
1975 F100/250 4WD from serial number W00,001 / 1976 F100/250 4WD.
D5TZ-6750-B = No specs listed / Marked D5TA-6750-DA
1975 F100/350 2WD from serial number W00,001 / 1976 F100/350 2WD.
1965/76 F100/350 FE: There are FOUR different 2WD & THREE different 4WD dipstick tubes.
good Morning Bill,
Resurrecting this thread. I have a problem with what I believe to be the wrong dipstick (likely from the 'correct' year truck, 1974 F100), with my truck. Unfortunately, the FE (390) engine in my truck is likely from a 66 Ford Fairlane. There are no part numbers on my current oil dipstick - only some dots that indicate Add and Full, along with an M or W.
Do you know the part number for a dipstick for a 66 Fairlane with a 390 engine?
Toplait
07-07-2015 10:08 PM
CampingFamily
06-04-2004 10:57 AM
