2wd and 4wd Truck Heights
Assuming the same type truck and tire size, what actually makes a 4wd truck taller than the 2wd trucks? Are there more leaves in the back on a 4wd, and are the coils just taller? Are the shocks different as well? How much taller are the 4x4 trucks over the 2wd trucks?
If I wanted my 1989 F150 standard cab 302 2wd truck to sit as tall as a stock 4wd truck, what exactly do I need to make that happen?
on
just remember,the lower they sit,the better fuel economy they can get, due to less flow traveling over the "dirty under garage".
this is the main reason 2wd's get better economy than 4wds.it's not so much due to the extra weight of the front axle and t-case,but less air low due to sitting lower.
consider enjoying your advantage.
I converted my 88 F150 2wd to a 4x4 by using a 89 F150 4x4 as a donor.
The 4x4 rear uses a 2 inch lift block. It also uses as you said
a leaf spring which has a couple of more leafs. The 4x4 spring is 3 inches
wide and the 2wd spring is 2.5 inches wide. I don't know how much
lift the 4x4 spring causes.
I kept the 2wd leaf springs.
For the front, the coil springs for the 4x4 measured 2 inches taller than the
2wd springs.
My truck sits level with no load in the bed.
On the 2wd I originally had 235 75 15 inch tires.
I installed 31 10.5 15 inch tires.
2wd springs.
court1100f
General Automotive Discussion
38
01-26-2011 10:48 AM
