7.3 coolant loss
7.3 coolant loss
Hi, I'm new to the diesel world and have chance to buy a 2001 7.3 with 160k on it but the motor has a blown head gasket (This is what the seller says). I am going to look at it myself this week and from what I've read here the 7.3 are not gasket blowers. I'm leaning towards cavitation of the block. Is there any way to tell by the coolant or oil? Check strips etc? Compression test? Any ideas that you can do while looking at it where it sits would be great. Thanks Ray
If the owner decided it has a blown head gasket just because it has water in the oil or oil in the water there are other more likely causes than a blown head gasket. Might be a real good deal.
You might ask what kind of anti freeze he has been using. I have not read of many of the later ones have a cavitation problems either. I think the cause of cavitation pin holes is old or wrong anti freeze; though I suppose there are other causes.
Last edited by White 99; 12-18-2011 at 09:55 PM. Reason: thought of something else
Yes I'll be asking more questions. Seems like he just wants to get rid of it and update to something newer. The more I read on the cavitation the more I'm thinking it might be something else. Thanks for all the replies everybody, any more ideas on what it could be or things to look for? I'll post when I get more info on it. Thanks Ray
But if there's enough coolant in the oil, it still may have wiped the bearings and need a full rebuild regardless of the source of the coolant.
Okay talked to the seller and he said that it would pressurize the radi and overflow tank. I asked if there was coolant in the oil and he said that he didn't look to see. I'm going to look at it later in the week if he still has it. I'm thinking cracked head maybe or injector cups. Any more ideas? Thanks for all the help so far. Ray
BIGG HUBB
12-17-2015 06:58 AM
mclaughlin16846
02-27-2014 07:32 AM
lemonshindig
31
09-30-2010 01:01 PM
2003, 73, antifreeze, blow, blower, chip, compression, coolant, ford, gas, loss, mind, overflow, performance, powerstroke
