Brake lights not coming on unless pedal is pushed hard
1995 F-150 5.0L, 5 spd (ZF S542)
Noticed the other day that the brake lights weren't coming on... after testing it seems they do if I push down the pedal hard.
I replaced the brake pedal switch. Same issue.
If I manually rotate the switch up to make contact, the lights come on.
Does anyone have a diagram of the parts for that brake assembly so I can see if I'm maybe missing a bushing or something?
There were just two white plastic pushrod spacers & the pin when assembling the switch, I didn't see any bushing.
Thanks!
Thanks!
https://www.ford-trucks.com/forums/1...ke-lights.html Have a read through this thread and see what you think.
tberr
10-28-2012 02:15 PM
