86. 4.9 (L6-300) No fire from distributor on cylinder 6.
Later came the VAX and DCL.
Perhaps so, I'm no expert on computers of this era and have never even seen a CDC machine (in real life).
I guess I'm the guilty party as I asked the innocent question that took us afield. But, it sure was fun! I was already aware that Chris knows about DEC computers, but now I know Bill and I worked on the same computer, the IBM 1620, and almost the same year except I did it in 1965-66 at Kansas State.
Oh well, hopefully cartmans_twin will enlighten us on what the problem was and/or what PIP means.
#28
#29
OK, cavemen . This fancy EEC-IV distributer supplies crankshaft position and frequency info to the computer using a Profile Ignition Pick-Up (PIP) in place of the crankshaft position sensor used on less-evolved models.
The PIP has metal tabs that rotate through the stator assembly (Hall Effect Switch). As they do, a voltage signal is sent to the computer indicating the 10 degree BTDC crankshaft position. The computer then calculates a precise time to energize the spark output signal to the TFI module on the distributor. When the TFI receives this spark output signal, it shuts off the coil primary current and the collapsing field energizes the secondary output. Fire and dino juice go boom.
This system replaced the analogue gadgetry of spinning weights, springs, and vaccum hoses found on your engines.
