Fuel Pressure Regulator Update Kit Install (Blue Spring)
#46
FYI...... The kit without the new cover ( Ford#6E7Z-
9C165-B IH#1854267C94) Does NOT come with the new poppet valve for the air bleed..... Is this a real big issue or should I not be concerned... I bought the kit and all the instructions that I see have been done with the kit with the new cover, and the kit with the new cover has the new poppet valve.....
I don't think I have to worry but want to know for sure that I will be ok....Would hate to have to rip it all apart again..... as long as I dont remove that Air bleed valve it should be ok right???
#47
#49
#52
#53
#54
If he didn't look it up for you, just jot down the part # and take it with you. That will get him on the right track.
I bought a couple of things the other day from the dealer and one was the grommet for the filter minder where it goes into the air filter housing. I had looked up the part# and had it with me. The regular parts guy wasn't there and the young girl at the counter put the # in the computer but it didn't bring the part up. I could see the screen and I'm sure she put the # in correctly. After a bunch of fiddling, she brought up an exploded view of the air filter assembly and I pointed out the part I needed. It wasn't in stock so she ordered it for me and when it came in, it had the part # on the package I had given her in the first place! I guess most databases that big have a few glitches in them.
#55
DieselDad55
FICM issue:
Batteries are OE Motorcraft, new last year. Cold V: 12.9v
FICM inspection: Key On Engine Off; 47.9v: Key On Engine Running, (cold engine); 19.4v.
Hence: Bad FICM !! I'll contact Ed today!!
#56
DieselDad55
What a GREAT thread. I got on to find info on my malfunctioning FICM, and I got all info I needed AND all this "extra" as well.
I will be looking into replacing my FPR with this "blue spring" update ASAP.
I am a computer idiot, can some one tell me how I can "save to my favorites" as mentioned earlier in this thread?
Thanks to all who contributed, this forum is awesome!!
#57
If you are on a Windows computer using Internet explorer, just click on the word favorites at the top of the screen. A drop Dow list will open and the first item at the top says "save as favorite". When you click that a box will open asking where you want to save at? If you just click save it will show up on the main list. There's a little check box that says "make new folder" put a check in the box and type in a name for the folder, I have one named automotive I keep all this stuff in but you can name it anything. When you want to find it later click favorite at the top of the screen scroll down to automotive (or what ever you named it) and click again. A list af any links you have saved will show up there.
#58
idk how popular this thread still is, but maybe since i replied it will go 2 the top and i can get a response. when i remove the fuel line from the regulator, does that allow air to get into the fuel system like it would when you run the vehicle out of diesel. if so, what is the process to get the vehicle started again and the air out of the fuel line.
#59
I used the same procedure when I changed the fuel filters.
#60
