1999 lightning need help please!!
I just purchased my first lightning and when driving home it would stumble bad from 3/4 to WOT. it idles fine and up to 1/2 throttle is fine. it has CAI and after market exhaust. has 100,000 miles. also when i was full throttle the boost gauge would go way past 10 psi, it would bury the needle. it was 25 degres today. this is my first supercharged car. were do i start? not sure what was done to it before i bought it besides the intake and exhaust. Hepl i am afraid of blowing something up.
Like phil said,dont be goin WOT in 25 degree weather...And when you go WOT,have the overdrive turned off also.Seeing that it has 100k,you should pull the intercooler,clean it and put some fresh plugs in it.
Sounds like it may have a lower pulley on it also..Id try to find out info from the last owner so you can know what all has been done to it...More background info will be better for you in the long run
2000lightning22
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
01-31-2012 09:14 PM
Stroh
05-03-2004 06:46 AM
Shift1
06-29-2003 10:10 PM
blue2002
08-29-2002 09:48 PM
5150
04-15-2002 10:22 PM
