Tinman's '51 Cabover lowbuck build - Page 3 - Ford Truck Enthusiasts Forums
  #31
Old 01-01-2012, 10:15 PM
tinman52
tinman52 is offline
Welder User
tinman52 has a superb reputationtinman52 has a superb reputationtinman52 has a superb reputationtinman52 has a superb reputationtinman52 has a superb reputationtinman52 has a superb reputationtinman52 has a superb reputationtinman52 has a superb reputationtinman52 has a superb reputationtinman52 has a superb reputationtinman52 has a superb reputation
Yeah, the drip rails are growing on me......we'll see what happens. I was blown away by the pic.....
  #32
Old 01-02-2012, 02:22 AM
badger_hound's Avatar
badger_hound
badger_hound is offline
badger_hound is gaining momentum as a positive member of FTE.
Very cool so far tinman. The proportions on that 1/4 window look great... but... have you considered a slightly more utilitarian shape? Something more like a sleeper cab window maybe?
which was posted by 48fordcoe... and:
posted by Bob Jones here:
https://www.ford-trucks.com/forums/7...e-sleeper.html
And my vote is also for extending the drip rail - I think it looks more fitting.
  #33
Old 01-13-2012, 09:26 PM
tinman52
tinman52 is offline
Welder User
Nothing real exciting going on......just a lot of welding. The cab corners I ordered were useless, so I sent them back. I ended up just making my own like always, it was actually easier. COE's have a slight rocker panel under the door which extends around the cab corner. I used some bent 1" tubing I had laying around....still a lot of fiddling around. They won't look factory, but I honestly don't care.....as long as the rust holes are gone!
When I get the cab corners done, I will make the subframe/mounts, then onto the sides.
  #34
Old 01-13-2012, 10:10 PM
Jeff and Nicolle's Avatar
Jeff and Nicolle
Jeff and Nicolle is offline
Jeff and Nicolle has much to be proud ofJeff and Nicolle has much to be proud ofJeff and Nicolle has much to be proud ofJeff and Nicolle has much to be proud ofJeff and Nicolle has much to be proud ofJeff and Nicolle has much to be proud ofJeff and Nicolle has much to be proud ofJeff and Nicolle has much to be proud of
Looks good to me Scott! You must have heat!
  #35
Old 01-14-2012, 10:38 AM
NtShade
NtShade is offline
NtShade is starting off with a positive reputation.
Looking good! I am waiting on my hay man to come weld for me.
  #36
Old 01-14-2012, 01:57 PM
cornerwindows
cornerwindows is offline
cornerwindows is starting off with a positive reputation.
The front tires fit in the fenders a lot better than most chassis swaps. I'll be watching this one
  #37
Old 01-27-2012, 10:08 PM
tinman52
tinman52 is offline
Welder User
Well, I've been doing a lot of welding......got the cab corners, rockers and cab mounts all done. I even cleaned up the bottom of the cab and sprayed some primer on. Then I slathered some bed liner on the flat panels to cut down resonance (If I ever get it on the road, LOL). I haven't made the front cab mounts yet, need to have the cab on the frame for those.
Next I am going to start on the sides.....
I got a line on an engine/trans......455 Olds? Gonna check on it tomorrow.....
  #38
Old 01-27-2012, 10:16 PM
sdetweil's Avatar
sdetweil
sdetweil is online now
sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.
nice work!..
Sam
  #39
Old 01-27-2012, 10:21 PM
arrowheadfred's Avatar
arrowheadfred
arrowheadfred is offline
arrowheadfred has a good reputation on FTE.arrowheadfred has a good reputation on FTE.
CAN'T WAIT TO SEE IT.
  #40
Old 02-04-2012, 10:55 AM
tinman52
tinman52 is offline
Welder User
Some more progress......been doing a lot of welding and grinding. Got the lower sides both done. Also had to repair a rotted lower door post.
Starting to look like something......
On to the windows!
  #41
Old 02-04-2012, 01:03 PM
51PanelMan's Avatar
51PanelMan
51PanelMan is offline
51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all
Did you form the new section out of sheetmetal or did you use spare doors and just cut to fit?
Would this help you in any way?
  #42
Old 02-04-2012, 08:27 PM
tinman52
tinman52 is offline
Welder User
Yes I used a couple extra doors......much easier. That roof looks pretty good, wish it was closer. I have a couple extra cabs for parts, but they are kinda rough. I plan to use an entire roof skin from another vehicle.....
  #43
Old 02-04-2012, 09:30 PM
bobbytnm's Avatar
bobbytnm
bobbytnm is online now
Roast em' if you got 'em
bobbytnm has a brilliant futurebobbytnm has a brilliant futurebobbytnm has a brilliant futurebobbytnm has a brilliant futurebobbytnm has a brilliant futurebobbytnm has a brilliant futurebobbytnm has a brilliant futurebobbytnm has a brilliant futurebobbytnm has a brilliant futurebobbytnm has a brilliant futurebobbytnm has a brilliant future
Great build thread! You do fantastic work.
The 455 Olds should make a great powerplant for this truck. They are great engines and make a lot of torque.
Thanks for all the pics
Bobby
  #44
Old 02-04-2012, 09:41 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is online now
ALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputation
Looks great so far! It would be "cool" (pun intended) if you made the quarter windows so they popped out at the rear, hinged at the front, for ventilation. With flat glass you have a lot of options.
  #45
Old 02-04-2012, 10:10 PM
52 Merc's Avatar
52 Merc
52 Merc is offline
52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of
Scott, if you still need cut-upable sheet metal, roof, doors, etc., keep me in mind. I've got a cab with a good top and a rotted away bottom ready to cut up, and a heck of a lot closer than Ilya.
Quick Reply: Tinman's '51 Cabover lowbuck build
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
