engine compatibility
Old Oct 31, 2002 | 09:16 PM
fordtruckdudeman's Avatar
fordtruckdudeman
Hello,
This is my first time on this site. I have always owned ford trucks of one type or another. I recently bought an 88 f-150 long bed with a 351w. A compression test later and number one hole is dead. I pulled the head and the piston has a hole. My question is about whether a 351w engine from say an 85 wagon will work as a bridge while i build an engine that i want. I don't know about the wagon engine and will check it out on monday. Another question is if it is not fuel injected will my intake fit. Any thoughts would be helpful.
Thanks
ps Happy Holloween
Old Nov 4, 2002 | 07:18 PM
edenroadmaster's Avatar
edenroadmaster
the wagon motor will work, just make sure the ignition is the same type (ford used some screwy ignitions during the 80s). if it isnt, use your distributor from your 351. also you may have to change the oil pan and oil pump pickup tube. (im not sure the double sump pan from the wagon will fit in your truck). if your tuuck has efi, switch it over too. for any other questions, you can drop me a line at edenroadmaster(No Email Addresses In Posts!)
WELCOME TO FTE!!!!
edenroadmaster
Old Nov 4, 2002 | 07:46 PM
steve83's Avatar
steve83
Where are you & how soon do you need an engine?
Ad removed by admin.
<!-- Admin edit: I have a '96 5.8L MAF from a '96 EB Bronco with about 60Kmi. ---> You'd have to do a lot of rewiring, but it'd be a LOT more worthwile than putting an OLD engine in. I've put a '95 engine into my '83, so it's certainly do-able.
Old Nov 4, 2002 | 07:52 PM
Mil1ion's Avatar
Mil1ion
Please use the e-mail system rather than the message boards if you want to sell him an engine.
[font color=red]Dennis
FTE Assistant Administrator
[/font]
[link:www.ford-trucks.com/guidelines.html|Club FTE]
[link: motorhaven.autoanything.com|How YOU Can Support This Site]
http://www.clubfte.com/users/mil1ion/canada_flag_animated.gif
[link:www.clubfte.com/users/mil1ion/Mil1ion.html|My Website,"North Of The 49th"]
Old Nov 4, 2002 | 10:40 PM
fordtruckdudeman
thanks for your reply. i have not had a v-8 engine since my 64, but am looking forward to fixin this one up. i checked on that engine, it is from a 79 sedan. it runs smooth and the compression checks good. will this still work ? i just want the truck running through the winter as i work on the rebuild.
thanks again
Old Nov 4, 2002 | 11:08 PM
steve83's Avatar
steve83
No problem - I figured it was a legit post since I thought I was pushing the idea of an EFI swap more than strictly selling MY engine, but I'll do it differently next time.
Old Nov 6, 2002 | 10:58 AM
Tony95F150's Avatar
Tony95F150
Old Nov 6, 2002 | 05:08 PM
edenroadmaster
as long as its a 351 windsor it will work. the outer dimensions are the same all the way to the newer 5.8 motors
eden
EvanBly
Transit Connect
13
Oct 3, 2016 09:44 AM
Club Wagon
Feb 3, 2009 10:34 AM
Club Wagon
15
Sep 11, 2007 08:13 AM
rsalter66
May 28, 2007 10:15 AM
banky
Sep 11, 2003 05:44 PM
