Rag joint splines
Old Dec 12, 2011 | 06:27 PM
Matthew in SD's Avatar
Matthew in SD
Rag joint splines
Hello...new guy here. I have a 1972 F-250 Camper Special, 2WD, 390.
In replacing my power steering gear box, I am also having to replace my rag joint. It looks like on my rag joint, the splines on the part that connects to the gear box I thought looked worn on one side, but I was looking at this picture https://secure435.hostgator.com/~dlv...UZ-3A525-A&s=0 and it looks like that one is "worn" on one side too!
So, I guess my question is, were these splined all the way around, or did they have a section that was not? I'm trying to figure out if I want to rebuild the one I have or get one of those borgeson vibration dampening u-joints. If they were not splined all the way around, mine looks to be in ok shape and rebuildable.
Any help is appreciated.
Old Dec 12, 2011 | 09:49 PM
Rogue_Wulff's Avatar
Rogue_Wulff
I cannot remember if the collar was splined all the way around. The shaft is, and the collar can slide on at any degree of rotation, best I recall.
The bolt tightens the collar around the shaft, so a little wear on the splines, or a blank spot, shouldn't be much of an issue, as long as the bolt is properly tightened down.
Old Dec 13, 2011 | 05:12 PM
Matthew in SD
Cool, I went ahead and rebuilt the rag joint last night with a kit from Napa. Gonna put it on tonight and hopefully have a driving truck again! Thanks for the reply.
Old Dec 13, 2011 | 08:45 PM
cj06's Avatar
cj06
i thought that the splines had a flat spot so it could be indexed one way ???
Old Dec 14, 2011 | 12:30 PM
Rogue_Wulff
Ok, yesterday I was working on my 74, and there is an old rag joint laying in the bed. The splines did not go completely around the inner portion of the clamp. I suppose the blank spot is there to allow the clamp to compress around the shaft easier.
When I had the steering gear off, I remember it did not have any king of blank spot, or flat area on the splined shaft (AKA "Blind" spline). The rag joint could be slid on at any degree of rotation.
Granted, this truck is a little newer, but I suspect Ford didn't change the design much between 67 and 79. They are famous for not "fixing" stuff that isn't broken.......
Old Dec 14, 2011 | 02:07 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by Rogue_Wulff
I was working on my 1974 and there is an old rag joint laying in the bed. The splines did not go completely around the inner portion of the clamp.
Granted, this truck is a little newer, but I suspect Ford didn't change the design between 1969/1974, some 1975's.
C9UZ-3A525-A (replaced C9TZ-3A525-B & D3TZ-3A525-A) .. Steering Coupler (aka rag joint) / Obsolete
Applications: 1969/74 F100/250 2WD & F350 // 1969/74 Econoline // 1975 F100/250 2WD & F350 all with Manual Steering only.
No Ford Dealer or obsolete parts vendor has any, but DORMAN has it.
Old Dec 15, 2011 | 09:05 AM
Rogue_Wulff
I was really referring more to the shaft and collar, rather than the entire coupler. I know there were a few changes made as to the size of the pins that stick out towards the top, so the complete unit would be listed by the specific years they fit. I certainly did not intend to imply that the entire coupler unit was the same during the entire 67-79 production run. If they were, I doubt there would be extra parts included with some of the rebuild kits.
shorerider16
18
Jul 22, 2016 06:48 PM
1983F1503004x4
Mar 5, 2013 11:57 AM
78 Ranger
Feb 10, 2008 11:59 AM
FTWDEVIANT1
Offroad & 4x4
Feb 10, 2008 10:32 AM
Brian794x4
23
Feb 19, 2005 05:05 PM
