What causes driveshaft to move back and forth when turn by hand?
I changed the oil in the truck today and while I was under, I noticed I could rock the driveshaft back and forth ever so slightly. Does anyone know if this is normal or if it is a bearing or... Thanks guys!
normal condition. as stated above you are moving the backlash between the ring and pinion gears. without that there is tension on the gearset all the time and you would end up with some bad juju. while doing that however, watch the ujoints. if you see part moving without another part..... time for new ones
