Bronco II Ford Bronco II
86 Bronco 2 Clutch issues
Old 12-24-2011, 01:01 PM
danboy282's Avatar
danboy282
danboy282 is offline
Question 86 Bronco 2 Clutch issues
I just bought an 86 Bronco 2 eddie bauer 4x4, and the guy i bought it from put a new clutch in it said he drove it for a little while and now the clutch won't engage (stuck in or out of gear). I believe it to be just a matter of bleeding the system, but I am not sure exactly on the procedure. Is the salve cylinder on the firewall, or is it one of those concentric slave cylinders that mount over the input shaft in the bell housing? Or does it have both?
Another thing, the guys dad (previous legal owner) told me his kid(driver) may have used power steering fluid instead of DOT 3 brake fluid. Obviously, I will need to flush the system thoroughly, but will it affect the slave cylinder or tranny in anyway.
Thanks for helping out a F.N.G.
Old 01-07-2012, 01:05 PM
critterf1's Avatar
critterf1
critterf1 is offline
Every component with rubber will need to be re-placed
Way2phat
1978 - 1996 Big Bronco
10-26-2010 06:06 PM
TheRon
Bronco II
10-13-2008 10:16 PM
treypastor
03-04-2008 08:45 PM
4baxter
01-03-2006 02:20 PM
frog73
12-27-2004 02:06 PM
Quick Reply: 86 Bronco 2 Clutch issues
