12,500 lb winch for $399.99 ?
#31
#32
Actually, stuck in the mud it can get far worse. The weight of your vehicle if stuck up to the rims. Twice the weight of your vehicle if up to the hubs. 3 times the weight of the vehicle if up to the body. and then compound it if there is any grade at all.
Just stay clear of deep mud!!! (you should anyway!) Everywhere else should be fine.
The link below is a fun read about recovery towing
Pirate4x4.Com - Extreme Four Wheel Drive
#33
I know.....but theoretically........with a 9k lb rating....and my Ex were standing on the back bumper it would lift it right off the ground with room to spare......stuck in the mud with rolling wheels should be much less........an angled pull would worry me most !
If it is designed like most.....it is rated with a 0.75 SF (safety factor)......meaning it is really 12k.....and down rated to 9k. Even if it's not the standard 0.75.....it has to have some SF
I would agree about a safety factor in the reciever you are looking at. God only knows what it is. I guess you could email reese or curt and ask them.
One other thing, since you mention safety factors. Almost evrything you will buy for the winch has a rating or weight capability stated for it. In most cases, that is the Yield rating. No safety factor.
When they say a shackle or wire rope is able to handle 16000lbs, you can bet that is the breaking point.
I chose all of my recovery equipment and accessories to have a higher yield rating than my winch rope. Since I have a synthetic rope that is rated much higher than my winch, then I hope the winch will stall first. If something breaks, it will be the rope first. Synthetic ropes do not whip back with deadly force like wire ropes when they break
I don't know if you ever saw my recovery gear, but it is shown in various places throughout the following thread:
https://www.ford-trucks.com/forums/9...fications.html
#34
#35
Good info !.....Thanks for the link .....great reference material ! .the "mire" above assumes the wheels are unable to move "damage resistance" included
#36
#37
#38
As far as frying the winch, get the HF warranty. Doesn't mean you'll get home that day - but you can at least sell the replacement winch and get a WARN!
#39
The 2 best pieces of advice I got when shopping for a winch:
1) You will never hear someone with a Warn on the trail,should it happen to break, say they should have gotten the Badlands winch.
2) Any winch is better than none at all!
I went with a Superwinch and have no regrets. If you arent going to rely on it a lot see #2. I have also found that once you have one you find all kind of things to do with it
#40
#41
#43
#44
Yep, I saw that...
I've used my 9k lb winch a dozen times or so now. I don't have enough battery for a long pull, when voltage drops enough - it stalls. Otherwise, no complaints except my confidence will certainly get me in trouble eventually. We go places we would have never gone before and pick lines that are sometimes ridiculous - because I 'have a winch'... After 'wheelin for basically 30yrs w/no winch, I suddenly feel invincible! Surely, this will change when I get in a bind somewhere and spend all day recovering my junk from a bad spot!
#45
Yep, I saw that...
