in line heater ?
Old 12-10-2011, 04:44 AM
miottimouse's Avatar
miottimouse
miottimouse is offline
in line heater ?
would any one have and "installed pic" of an inline or circulating heater in their truck? i installed one on my 79 bronco,it lasted 1 day and burnt out i would just like to compare installs to make sure it was done right as my bronco being a wash/u.s.a. truck did not come with block heaters and the 400 will be swapped out for a built 460 next spring i did not want to go through the trouble/expence of block heaters for only 1 winter thanks
Old 12-10-2011, 10:34 AM
RWENUTS's Avatar
RWENUTS
RWENUTS is offline
I don't have a pic but have used them without a problem before. An easy cure till spring is get a magnetic oil pan heater. Lots of big trucks and tractors use them.
Old 12-10-2011, 02:57 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Originally Posted by miottimouse
would any one have and "installed pic" of an inline or circulating heater in their truck? i installed one on my 79 bronco, it lasted 1 day and burnt out.
i would just like to compare installs to make sure it was done right as my bronco being a wash/u.s.a. truck did not come with block heaters and the 400 will be swapped out for a built 460 next spring.
Engine block heater kits were available at the parts counter.
D6AZ-6D008-A .. Engine Block Heater Installation Kit / Obsolete
Last MSRP: $55.91 / Dealer net cost: $39.14 / Applications: 1976/79 302/351M/351W/400/460.
JIM WEBER FORD in Wishek ND has ONE = 701-452-4288.
HIGHT FORD in Skowhegan WI has ONE = 207-474-3334.
WESLEY OBSOLETE PARTS in Liberty KY has ONE = 606-787-5293.
TISON MOTOR CO. in Estill SC has ONE = 803-625-2551.
FREESE MOTORS in Monticello IA has TWO = 319-465-3541.
SEEKINS FORD-LINCOLN in Fairbanks AK has TWO = 907-459-4000.
No other FoMoCo Dealer or obsolete parts vendor has any.
Old 12-11-2011, 12:37 AM
Bullitt390's Avatar
Bullitt390
Bullitt390 is offline
Certified Thread Hijacker
Shouldn't be anything to it. Most likely just defective from the start.
Was it the heater hose style or the lower radiator hose style? I have never heard anything good about the lower radiator hose units, but have used the heater hose before.
The only other possibility is installing it in the lower heater hose (return) instead of the upper hose. May not circulate the coolant as well?
Just a thought.
Although if I had to choose one over the others I would pick the oil pan heaters.
Josh
Old 12-11-2011, 06:10 AM
miottimouse
thanks guys i think i got it right now on the 1st install i tied in to the hose from the water pump but think i got an air lock due to it going over the alt this time i used a t fitting off the water temp sending unit hole putting the hose fitting straight down and under the alt seems to work good now with the bonus of installing my new oil/temp/volt gauges as the water temp fitting was fairly big with a back up heater when my 460 goes in with block heaters all ready installed regurds joe
IDIDieselJohn
02-28-2012 11:57 AM
WhiteBeast-05-powers
09-20-2011 10:44 AM
tmcalavy
04-10-2011 08:05 AM
backhoeken
11-25-2006 04:55 PM
Quinny
1983 - 2012 Ranger & B-Series
11-02-2005 08:42 AM
Quick Reply: in line heater ?
