jjoyner 2005 Expedition misfire #6 and goes down hill from there
My 2005 Expedition had a misfire at #6. I replaced all the plugs and the COP at #6. I went to crank it and it acted like the battery was dead, but a second try minutes later and it started right up. I still had the misfire so I went back to work on #6 and this time when I cranked it up I started like a carb. system rather than fuel injected but did finally start, but I still had a misfire. The next day I switched injectors 5 and 6. This time when I went to start it nothing. It will turn over a couple of times then just "click". This time however I lost power to the radio and gauges. I unhooked the neg cable and re hooked and all the gauges and radio worked fine until I again tried to start it with no luck and gauges and radio went out again. Any ideas?
ExpySport
1997-2006 Expedition & Navigator
13
12-12-2008 10:57 PM
