1987 F250 Bigfoot Cruiser 460 V8 not charging
#31
#32
Ryan sells the stator pigtail.
It is the same as the 3G.
RJM Injection Tech — Alternator Regulator pigtail
Ebay, PICO WIRING 5702PT Wiring Harness Pigtail Voltage Regulator 3 Pin Tan Ford Ea on eBay!
Pico # 5702pt
Standard # 5354
Pico # 5702pt
Standard # 5354
#34
Thank you everyone!!! Both pigtails were bad and had to be replaced. After replacing and making sure I SOLDERED them inline instead of using crimps I put the volt meter across the battery while engine running and volts read 14.6V, battery light is out on dash and volt meter in dash shows 15V. It finally got warm enough to get out and do it and it WORKS!!! Thanks guys. And I guess this thread is resolved and closed.
Rugratt69
16
03-14-2019 11:07 PM
