Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: 4WD Guides
- How to Replace Rear Differential
Step by step instructions for do-it-yourself repairs
Electronic Locking Rear Differential Question
#31
#33
The TJ/LJ Rubicons are not Electronic Locking Differentials. As far as I know ARB has never made an ELD, either. Instead, those selectable lockers are powered by air pressure (pneumatic).
#34
Try searching Tousley Ford or other such places. I don't know what all is involved, but if you don't need it to go through the factory switch, it shouldn't be difficult. Aftermarket (e.g. Eaton) electronic lockers simply need you to put a switch on it. Current flows, it locks. Break the circuit, it unlocks. Easy enough. I doubt the Ford system is more complex in the actual components at the diff, though the nanny system will unlock it for you based on other inputs like speed even if you have the selector switch pulled out to engage.
Just tried Tousley cause I hadn't tried there yet. I found parts called differential assembly with variants including "w/ limited slip" and "w/o limited slip" but that's the only designation, no "elec locking".
#35
I have installed the ARB products, not all that difficult, in all likelihood you will need to be able to set up a R&P or you can install it and just have some guy come by and set up the R&P for you.
ARB makes the for Ford Dana 60's and the Sterling: Vehicle Page
#36
An "Electronic Locking Differential" is a specific thing, where electric current activated an electromagnet to lock he axles. Other methods of activating locker mechanisms include pneumatic (air powered like ARB) and cable driven (OX). Using "ELD" as a generic way to reference a selectable locker is neither accurate nor advised. It only creates confusion, especially since ELD is exclusively used within the modern Super Duty crowd.
OP, the easiest option for you is to pull a rear axle with the right gear ratio and e-locker from a wrecked truck where the rear axle isn't damaged. Swap it and done. Otherwise you can throw an auto-locker in it, such as a Detroit or Yukon Grizzly. Any such option is a major and expensive undertaking. You'll need an axle master overhaul kit, new gears, someone to set those gears up for you, and air pumps if it's an ARB.
ARB:
http://eastcoastgearsupply.com/i-138...pline-all.html
https://www.ford-trucks.com/forums/1...-and-info.html
Auto Locker:
http://eastcoastgearsupply.com/i-822...-fits-all.html
ARB:
Auto Locker:
#37
That was my next thought...probably would be the easiest, and I can get some F350 blocks and springs then as well!! It's a win-win.
#38
My .02 worth. I have an 11 with ELD and I plow with it and I used the ELD all the time versus 4WD. Much easier on the drive train while turning. I also have a 12 that doesn't have a ELD option and I recently got it stuck in some show while in 4WD. While in 4WD, if 1 tire grabs, the other side just spins. This on front and rear! I'm definitely a big fan of ELD.
#39
I find ELD useful on steep, rocky forest road climbs. When your wheels bounce on rocks under power, there are breaks in traction when one wheel comes up, spins, gets all the power, accelerates and slams back down. Engaging ELD will smooth out power delivery because both turn at the same rate and the wheel on the ground will keep pushing you while the other bounces up. Truck feels a lot more surefooted.
Using 4WD in this situation is not good because of locked up nature of the transfer case. You'd have to go slow and hope nothing breaks. It's times like these that fulltime 4WD is useful. But, in many cases, ELD does the trick in 2WD.
#41
Agree!! I use 4x4H or 4x4L with and without the ELD (whatever combination works best in the situation) on steep wash boarded grades to reduce the effects of the wash boards on the truck.
#42
Question without starting a new thread...eeveryone keeps saying that the front axle is not locking or whatever, that one wheel will spin while the other one sits there when in 4wd. I've had to use 4wd several times over the last few weeks because of the snow we've been getting around here. When I turn while in 4wd, I get the binding bump feeling'noise from the front end that I know is both wheels trying to turn the same amout. If my front end isn't locking, why does it do that?
Thanks
Ken
Thanks
Ken
#43
Question without starting a new thread...eeveryone keeps saying that the front axle is not locking or whatever, that one wheel will spin while the other one sits there when in 4wd. I've had to use 4wd several times over the last few weeks because of the snow we've been getting around here. When I turn while in 4wd, I get the binding bump feeling'noise from the front end that I know is both wheels trying to turn the same amout. If my front end isn't locking, why does it do that? Thanks Ken
#44
If the front axle is limited slip too, then why does it bind? That is my question.
#45
Edit: in short the front axle travels farther than the rear while in 4wd.
