Need help identifying diff problem
Old Dec 7, 2011 | 12:01 PM
serious_lee's Avatar
serious_lee
I am looking for an old 4x4 so I've seen a couple trucks around town. One of them is a 1990 f250 that seems to have had a Dana 60 swap on the front. There seems to be a problem with the front diff that I can't figure out. Here's the test I performed and maybe somebody can help me figure out if I should run away or attempt to buy/repair this thing.
With the transfer case in 2H, hubs unlocked, and rotating the front driveshaft by hand, I feel resistance in one spot of a full rotation. The u joint closest to the diff seems tight, but the one by the transfer case is pretty worn. I can jiggle it back and forth maybe 1/16 of an inch when I grab the front axle. Everything moves when the shaft is rotated, so I don't think there is anything broken but it feels like gear binding to me. I've never worked on a 4 wheel drive, so any insight to this would be very helpful. I do all my own car work and I am a service engineer, so I am no stranger to a wrench. I'm just worried that a new front diff may be needed and that could turn into some big cash.
Thanks,
Everett
Old Dec 7, 2011 | 12:17 PM
Phy's Avatar
Phy
It could be in the front diff, one of the u-joints in the drive shaft, or in the t-case.
Disconnect the driveshaft at the front diff & turn the pinion yoke...
Old Dec 7, 2011 | 12:49 PM
f-trucker88's Avatar
f-trucker88
some resistence is normal, but it sounds to me it may just be a universal. good luck!
Old Dec 7, 2011 | 01:20 PM
Lazy K's Avatar
Lazy K
A stiff/frozen universal joint in one of the front axle shafts could cause what you describe as could one in the driveshaft.
Old Dec 7, 2011 | 01:42 PM
serious_lee
Is there anything useful that jacking the front end up, locking the hubs, and spinning one tire is going to tell me? I had an idea that this would isolate the driveshaft u joint without taking anything apart. Is it like a front wheel drive car where the other side spins opposite with no load? I guess that wouldn't rule out the axle u joints though.
Old Dec 7, 2011 | 07:32 PM
toby tough's Avatar
toby tough
I think it's one of the u-joints.IMO if it was in the diff. it wouldn't be in just one spot.
Old Dec 8, 2011 | 06:16 AM
serious_lee
Thanks for the replys! That makes sense now that I think about it. I bet it's that one right there at the diff yolk since it feels tight. The truck's been sitting for a while and I don't think 4x4 has been engaged for quite some time.
brian1080
20
May 23, 2015 08:30 PM
Auctioneer NJ
17
Oct 17, 2014 08:46 AM
f350rebel7788
Sep 26, 2011 05:08 PM
bobbyt89
Jan 1, 2011 10:26 PM
1984 f250
17
Dec 25, 2004 10:30 AM
