just finished build of motor, installed flexplate, digging thru parts, found metal "spacer" ring, it is a little bigger than the crank flange that flex plate sits on.
how important is the "spacer"
this is my first ford, learning lots
That spacer goes under the bolts to provide a "crush" area. Is it needed? Well, Ford used it for a reason, but us shadetree mechanics just torque down the bolts with lock-tite
many thanks
it helps to keep the flex plate from cracking around the bolt holes.
MIRAMAR FORD TRUCK in San Diego CA has 2 = 858-450-1707.
PARTS INTERNATIONAL in Farmers Branch TX has 34 = 888-727-0418.
GREEN SALES CO. in Cincinnati OH has 192 = 800-543-4959.
NUMBERDUMMY is corect it is a flywheel REINFORCING plate not a spacer it is sort of like having washers under the bolts . helps distdribut the clamping loud of the bolt and keeps the bolt frome marking the flexplate witch cause stress cracks .needed ? ur call.
