New here and need some help/insight
I'll take the remans. Never had any issue using reman stuff before.
Good to know info on the glow plugs. I had no idea. I'll probably end up doing all this pretty soon. Is there a how to for the injection pump on here?
Also, what's a good turbo kit for the truck? If I go turbo should I wait and have an exhaust made after its turbo'd? If I turbo it, what should I do to the motor? What is studded? Different head studs?
TikiWiki : IDI Fuel Injection Servicing
I had trouble with my install because I had a bad injector that I mistook for bad timing and or a bad IP. Don't forget you will need a way to set the timing for the new pump. I bought a timing meter designed for these engines but I know there is a rental program going on over at oilburners.net.
Thanks, man. I'll have to get some updated pictures. I painted it about 7 months ago and put some later model wheels on it but have yet to take any photos.
Either buy online or find a good hardware store to get the 5/16" 16 point socket, 9/16" open ended crow foot and some swivels and extensions. You can bypass the crow foot if you have the ability to make a wrench that will fit the nut on the IP flange on the passenger side. You will also need a torque wrench.
Are you getting the return kit from Russ? If not, buy a pack of #111 viton O-rings and use them instead of the ones that come with the return kit.
Diesel Performance Specialists, Inc. - The Diesel Performance Specialists
a good place to look for pumps and injectors
Ahhh...gotcha. I'm pretty sure I have a 5/16 16 point socket. Thanks for the heads up.
#28
