Something big, loud and slow in my driveway
#31
#32
If the wheels are straight, and van moving, turning left isn't bad, it's a lil stiff, but fine enough to drive, but the wheel never comes back to center, I have to bring it back.
Now running straight, then turning right, oh boy it's stiff, most of the time, I can't even turn the wheels fully right at all! And once I do that, I hear a weird grinding noise coming from underneath. It's a weird rattle type grinding.
And the hole is over half inch wide..... that sures hell no grease nipple hole lol.
#33
I'm not saying you don't need to fix the kingpins, but I think you have another issue as well...
All in all though, if the underside is rust free, and it runs well, you got a good deal on a big *** van.
#34
I'm thinking that sounds more like an issue with the steering box than the kingpins. Yes bad kingpins will make it hard to turn, but shouldn't it turn the same left and right as the kingpins will be moving in both directions. Whereas the steering box acts differently depending on the direction turning.
I was beginning to think the same, because it's pretty odd how it operates.
I'll jack it up and turn the wheels in the air see how everything looks while turning, then I'll pop out the tie rods and see if I can turn the wheels by hand.
I also noticed getting on or off ramps, when holding the wheel turned, I clearly feel the wheel pulsing, like it looses P/S pressure, gains it again, looses, gains over and over untill I go straight again, or turn a corner. Like the steering wheel pulses.
#37
I'm telling you that ac is right in the way everytime you turn around, and besides all it does is keep you from sweating.
Back when I was in high school and drove chevells and gTO's, things like that I would ditch the air conditioner at least at the very first engine change, so that later swaps would be quicker, also they were robbing power, then the first couple of pickups I bought were without air BECAUSE I was CHEAP, something I grew out of by the time I was in my early 20's. lol Though some might still tell you I am a cheap something or other. lol
#38
#42
What killed my love for them after the 92 model? ummm everything?
Ugly as hell exterior, way to ugly plastic modern interior, body lines, everything basicly. They just don't have the real 70's van look anymore. No class and no taste.
And this black one? It's a friend of mines van it's an 88 E150 with a 300 straight 6, C6
jayro88
10-28-2017 07:52 PM
TeachNlive4ever
10-23-2017 06:53 AM
Harlan Hobbs
19
03-23-2014 08:23 PM
Super Econoline
69
11-07-2013 01:21 PM
