'67 F100 Lug Pattern?
Old 12-06-2011, 01:17 PM
RubyRidge's Avatar
RubyRidge
RubyRidge is offline
I have seen where some are saying the lug pattern is 5 x 4.75 & some are saying 5 x 5.5
What is the lug pattern on a 1967 F100 SWB 2x4?? Thanks!!
Old 12-06-2011, 01:28 PM
elgemcdlf's Avatar
elgemcdlf
elgemcdlf is offline
5x5.5 is the bolt circle to almost every F100 2WD or 4WD. There are 3 yrs in the early 80's that had a smaller pattern.
Old 12-06-2011, 01:30 PM
RubyRidge's Avatar
RubyRidge
I was looking at a new set of the 5 Mustang 5 star (torque thrust) styled rim. They too are a 5 lug but I wasn't sure if they would fit.
Old 12-06-2011, 01:48 PM
elgemcdlf's Avatar
elgemcdlf
Not without some very expensive wheel adapters.
Old 12-06-2011, 02:23 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
5 lug wheels on a 5.50" bolt circle pattern: 1948/52 F1 / 1953/79 F100 / 1966/96 Bronco / 1969/2012 E100/150 / 1975/96 F150 / Some 1980/83 F100.
5 lug wheels on a 4.50" bolt circle pattern: Some 1980/83 F100's. Passenger Car wheels with a like pattern will not fit...as they will not clear the calipers.
Old 12-06-2011, 05:34 PM
Rogue_Wulff's Avatar
Rogue_Wulff
Rogue_Wulff is offline
Not only are they the wrong bolt pattern, but the offset (backspacing) is also way off. These wheels have the correct bolt pattern for the Ranger small truck (83+) but still won't fit, due to the offset/backspacing.
Old 12-09-2011, 12:11 AM
jhooch's Avatar
jhooch
jhooch is offline
5-4.75 used on GM and Jaguar. Never on a Ford.
svolpone
03-03-2016 03:15 PM
Choward
01-15-2010 04:22 PM
therockgod
20
06-01-2009 01:19 AM
79_effie
08-06-2004 08:40 PM
1979_f100_351M
03-08-2004 08:06 AM
Quick Reply: '67 F100 Lug Pattern?
