OK, I looked for the Upfitter wires, can't locate them
I have the 4 switches and they light up when on. I just can't find the wires to attach my accessories to. I removed the panel below the steering column and looked around to the left. Nothing. Brought in a flashlight, nothing...
Anyone?
Anyone?
on
Well... it's difficult for me to tell you where it is when I can't see under your dash either, so all I can suggest is look for the upfitter switch relay pack over by the left wall above the parking brake release and follow where the wires lead to. They click when you turn the switches on and off so you can figure out which box it is that way.
They will be a bundle of color coded wires and they will have bock end on them. Look up way up as they are ussually tucked up tight. In the same area are a series of larger gauge pass through wires. You need a bright shop light and a keen eye to find them.... There should be a color coding you can find to tell which are aux1, 2, 3 and 4. Unfortunately the bundles are ussually wrapped up so finding them is tougher.
I did locate them, they were really taped up pretty good. Now I have power for my adjustable Rancho 9000XL shocks' wireless remote control !
