Calling all part # guru's....numberdummy, mike, etc.
Hey guys. First off, i understand these parts are all likely obsolete....having said that I still would like the part numbers for the following. Sorry in advance for the long list. No rush! Much appreciation
These parts would all be for a 78 f150 8 ft box regular cab 4wd 4 spd 300/6 dual tanks.
right and left doors
right and left besides with square fuel doors
right and left fenders
right and left front plastic splash shields
right and left rear plastic splash shields
right and left window regulators
right and left door weather strips
vent window weatherstrips right and left
drivers side battery tray....wiring not needed
chrome grill
chrome square headlight bezels
bottom bench seat foam if a # exists???
all four complete cab mounts...seperate part numbers???
jade green metallic dash pad
jade green carpeted kick panels
alternator wiring feed harness
engine feed wiring harness
trans & transfer case shift rubber shift boots
window washer reservoir
brake proportioning valve...mounts on right side frame under cab
engine side cover for 300/6 engine
body stripe kit for 78 explorer....ext color is midnight jade...stripe kit is the two tone yellowish green.
I know thats asking alot!
I really don't need to know whether their obsolete or what all models they'll fit etc. Pretty much just want the Part #'s
Huge thanks in advance for any help
chrome grill
You can look up all these part numbers yourself, because...
The 1973/79 Ford LIGHT Truck Parts Catalog is available on a CD from hipoparts.com. This is the same catalog that mikeo0o0o0 is using, I'm using this catalog on FoMoCo microfiche slides.
I don't know about Mike, but this list is just too extensive for me to list all the part numbers. Some I can type "off the cuff" but most will require hours of research, you wanna know why?
Ford is in-famous for replacing (updating) 10's of 1000's of part numbers EVERY YEAR!
And in 1987/88, Ford changed the package quantity of a gazillion parts. When the idiots did that, they changed the part numbers suffix, rendering all the original part numbers obsolete.
So...it will take time searching thru the O-S-I (Obsolete-Supercede-Interchange) Catalogs to see if the numbers were replaced...or not. I have these catalogs, but AFAIK, Mike does not.
The CD version was scanned from an early 1979 addition, will have none of these replaced part numbers. The final edition of this catalog was printed 10/88, but is only available on microfiche ($125.00). I have it.
ALL these parts are obsolete. Some can be found NOS, most cannot. Some have been repopped.
The stripe kit...if found NOS will be NFG! These are composed of two layers, stripe and adhesive, came rolled up in a box.
Over time, heat causes the stripe layer to become adhered to the adhesive layer, so when you try and peel the adhesive layer off, bits and pieces of the stripe layer come along with it.
Now you've spent...lawd only knows how many buckaroos...for something that is worthless as teats on a mule.
Ford only sold the upper/lower cab insulators and the mounting hardware. The steel mounts were only furnished with the frame assy.
Ford sold the seat covers pre-sewn, the padding was only sold as Cushion or Back Kits.
The chances of finding any of these parts NOS (ditto the carpeted kick panels) are just about nil, as upholstery was the first thing Ford obsoleted.
Here goes a partial list....so far.....yeah, I don't have a life!
And Bill is right, I dont have a copy of the O-S-I book so some (all?) of these numbers may have changed.
Right door D9TZ-1020124-A
Left door D9TZ-1020125-A
Right Bedside D6TZ-9927840-B
Left Bedside (Single fuel) D7TZ-9927841-B, (Dual fuel) D7TZ-9927841-D
Right window regulator D8TZ-1023200-A
Left window regulator D8TZ-1023201-A
Door weather strip (R&L same) D8TZ-1020518-A
Right vent window w/strip D3TZ-1021448-A
Left vent window w/ strip D3TZ-1021449-A
Drivers side battery tray D8TZ-10732-A
Grille (chrome look) D8TZ-8200-A
R Headlight bezel (bright finish) D8TZ-13064-E
L Headlight bezel (bright finish) D8TZ-13064-F
Dash pad (green) D3TZ-1004282-B
You have a life Mike. It's making all of us happy/jealous/envious/stoked/humbled/ and just out and out pissed off that we don't have the patience and will to do the job you are doin on the Pumpkin.
Yup, pretty good life.
Hey Shane
Spend the twenty bucks on the DVD and you won't have to ask for such a huge list.
Its a huge help to have the shop manuals and the DVD.
http://www.hipoparts.com
Hey Shane
D9TZ-16005-A / D9TZ-16006-A
D6TZ-16102-A / D6TZ-16103-A
D7TZ-9928370-A
D7TZ-14289-M
D7TZ-7277-A / D3TZ-7277-A
window washer reservoir-less washer pump.
D1TZ-17618-B
bottom bench seat foam.
jade green kick (COWL) panels.
D5TZ-2B257-B
C5AZ-6519-B
D7TZ-9928370-A
D7TZ-14289-M
D1TZ-17618-B
D5TZ-2B257-B
C5AZ-6519-B
Cowl panels: With or without factory installed integral A/C?
Seat foam = Cushion Kit: Need the BODY code off the Warranty Plate.
hickory1991
22
05-26-2022 06:21 AM
CountryBumkin
07-18-2015 08:59 PM
hayward
03-31-2002 04:35 PM
