Need Gauge Mounting Opinions
How about over the rear view mirror....check this link out. https://www.ford-trucks.com/forums/1...in-my-v10.html
I like the pull handle on the drivers side...that would have to go if you use the pillar. As you can see I went over the rear view mirror.
2000 don't have grab handles on the drivers side...I added it from a 2006 then added the passenger side to match. 2005 and up are slightly different. Whatever location you use be sure to consider a separate dimmer for the gauges. If you follow the link above you'll find the gauges I installed were VERY bright. Having them hooked to the dash dimmer didn't work so good. Once I got the gauges to a comfortable level the dash lights were dark. Either location will look great...just wanted to provide another option to consider.
i put my 4 gauges on the piller.i got mine from GlowShift Performance Gauges & Pods and they came as a package deal fast shipping and work good.had them for almost a year.
I'm surprised everybody hasn't taken turns showing what their gauges look like. Is there someplace on the forum where something like this can be permanently displayed? To clarify, a "catalog" of gauge installs and everybody posts there for others to view. The same could be done with stereos, canopies, wheels, exterior lights, running boards, etc....
I don't like the lit gauges in my face, as the A-pillar mounting would have done. I installed under the dash and I just glance when I'm doing something that warrants looking there.
