Crossovers Edge, Taurus X, Freestyle, MKX, Flex etc.
2010 - Edge Noise
Old 04-13-2012, 02:36 PM
2010Edger's Avatar
2010Edger
2010Edger is offline
2010 - Edge Noise
Hello,
I have recently joined the forum. I have searched in many different ways before posting this to try and find this issue but was not successful.
I have a 2010 Edge I bought new. I have done all of the maintenance as suggested by the Ford Service Guide.
However now after driving the vehicle for 15 to 20 minutes at speeds of 110+kmh (60+mph) and then travelling for an additional 10 to 15 minutes at 80+kmh (50+mph) I notice a whining/squealing noise that increases in intensity until it drowns out the stereo and becomes unbearable. The noise will go away instantly if the brakes are applied, if you turn the steering wheel slightly, or if you pull over and allow the vehicle to rest for 5 to 10 minutes. The outside temperature also seems to have an influence on this since I have only experienced this issue during my evening drives home from work when the temperature is 14+Celcius degrees or approximately 60+ degrees Fahrenheit. It seems to be coming from the rear of the vehicle but it's really hard to know for sure from inside the cabin.
I would love to find a TSB to take to my dealer since they refuse to drive the vehicle long enough to reproduce the issue.
The vehicle mileage is currently has 65,000+ kms/40,000+Miles.
Any and all help with this is truly greatly appreciated.
Thanks,
2010Edger
Old 04-23-2012, 10:57 AM
senix's Avatar
senix
senix is offline
Received 1,407 Likes on 1,003 Posts
Have you considered taking it to another dealer? How about doing a video with sound as proof?
Old 04-23-2012, 11:17 AM
2010Edger's Avatar
2010Edger
I have taken it to another dealer, but no joy there either. The dealers won't drive it long enough to reproduce the issue. The video is a good idea that we have had as well. I will definately do it as soon as the issue occurs again. Thanks for your reply.
Old 04-23-2012, 12:17 PM
senix's Avatar
senix
senix is offline
See if this helps?
Make : FORD Model : EDGE Year : 2009
Manufacturer : FORD MOTOR COMPANY
Service Bulletin Number : SB-20725 Date of Bulletin : MAR 01, 2008
NHTSA Item Number : 10029567
Component : WHEELS
Summary :
FORD: SOME VEHICLES MAY EXHIBIT A GROWL/HOWL TYPE NOISE COMING FROM THE LEFT AND/OR RIGHT REAR WHEEL AREA. *PE
Check to Request Research. Submit below.
Old 04-30-2012, 06:23 PM
senix's Avatar
senix
senix is offline
Originally Posted by m.mcclure
Hello, are you a member of the ford edge forum?
Me? Nope. Just pulled the info from NHTSHA
Diesel Submariner
04-24-2011 07:04 AM
1967 Turbo 6.9
Kansas Chapter
09-28-2010 01:25 PM
nascar88ford
2004 - 2008 F150
07-06-2009 10:19 PM
white Buffalo
03-12-2008 12:27 PM
Quick Reply: 2010 - Edge Noise
