Truck died. Please help.
Old Dec 1, 2011 | 10:54 AM
Diesel 724's Avatar
Diesel 724
The other day my truck died while i was driving it. I was going about 40 just crusing and then i got no throttle response and it just died down real slow. AAA towed me home and its just sat until today. I took the fuel filter out thinking i ran out of fuel and my gauge was off but there is still about an inch of fuel in the bottom of the bowl. Any ideas please help me. I cant afford to dealership this truck...
Old Dec 1, 2011 | 11:05 AM
SARDiverDan's Avatar
SARDiverDan
CPS is my guess. Ford dealer sells them for about 30 bucks. You can get them off the internet for a little less but it all depends on how fast you need it fixed. Takes about 10 minutes to change it out.
Old Dec 1, 2011 | 11:10 AM
Diesel 724's Avatar
Diesel 724
I JUST put in a new international CPS "ghig" helped me find it. You think it failed in 3 months? I have a spare from an auto part store i can try?
Old Dec 1, 2011 | 11:15 AM
BillyBob69's Avatar
BillyBob69
Check the #30 fuse. If it is blown, unplug the fuel bowl heater then replace the fuse and try again.
Old Dec 1, 2011 | 11:31 AM
SARDiverDan
It is possible. My first CPS, when the truck was new, lasted about 5 months before it went out. The #30 fuse, as mentioned by BillyBob69, would be the next place to check. If the #30 fuse is not blown, change out the CPS and see what it does.
Old Dec 1, 2011 | 11:45 AM
PaysonPSD's Avatar
PaysonPSD
I agree with BillyBob. Only an inch of fuel in the bowl sounds like the fuel pump stopped running which would happen if under dash fuse 30 blew.
Can you hear the fuel pump run? Do you get a WTS light with key on?
Old Dec 1, 2011 | 12:03 PM
Diesel 724's Avatar
Diesel 724
Wow i just put in my old CPS and it fired right up! Why did my international part number 1876736C91 die so soon? I paid more for it then my cheapy Advance one and its lasted way longer?
Old Dec 1, 2011 | 01:22 PM
Brother Les's Avatar
Brother Les
Did you try to start the truck back up when it died? Mine 'died' like that when I went through some water.... after I stopped the truck I was able to start it right back up.
You may have had a loose connection or some moisture might have gotten past the o-ring and momentaryaly killed the truck.
I would not toss the international part as it may still be good.
Old Dec 1, 2011 | 01:40 PM
PaysonPSD's Avatar
PaysonPSD
Glad it was an easy fix. Install a new Ford OEM CPS and keep that Advance Auto CPS as a spare.
With only an inch of fuel in the bowl and the way it "died down real slow" I was sure it was a fuel problem.
I hope it's not an intermittent short in the fuel bowl heater, but that should have blown the fuse.
Old Dec 2, 2011 | 02:06 PM
Diesel 724's Avatar
Diesel 724
Well i did try to restart it and it wasnt having it. I cranked till i about killed my batteries.
dclack
21
Jan 23, 2012 11:19 AM
Sparkplugless
37
Jan 12, 2012 03:51 PM
mahause
Dec 5, 2009 11:05 AM
MissIndependent
74
Dec 4, 2008 08:40 PM
LUMBERMAN
17
Dec 23, 2007 05:10 PM
