Can anyone ID this rear end housing?
Sorry for the poor pics, Id like to go thru everything to make sure all is relieble, and the limited slip isnt so hot anymore.
I want to say a dana 41?, not to many vehicles with a 5 on 5.5 bolt pattern.
Axle Identification Chart
With it being 5 on 5 I would think it is a Dana 44 before a Dana 60 the look alike but the 60 is a HD rear end in 3/4 ton trucks and vans...where the 44 was used in cars, but you could be right. Can you find a casing date and ID stamps? Casting date is found look from the rear at the top left flange of the axle and the ID is found on the left lower...
Google GM 10 bolt rear end, if it has a 5 on 5 in bolt patern it's probably a Dana 44 used in Chevy pick-ups. If it's a 5 on 4 3/4 it's a Dana 27 used in cars. Sorry the Dana 27 was used also in chevy pickups with 6cly engines, thus giving it the 5 on 5 in bolt pattern.
Jimmy,
Based on the pictures I would say it is a small DANA 25,27 or 30. All use the same rear gasket. You can not base it on just the bolt pattern as just about every manufacturer has used DANA's in a variety of vehicles of different bolt patterns and it is easy to redrill or get new axles.
Here is a chart to better help you. Differential identification charts
Good luck
Good luck
Jimmy,
Good luck
Good luck
