Power gains? How much power for how much cash?
I have read all through many old threads about how to get more power out of these engines. To sum it up I found, add turbo, Larger exhaust, remove t in exhaust and put in a y open up air intake to increase flow, turn injector pump up, add moose pump, and type4's torque cam. I would like to know how much power you get from these individually so I can compare that with the cost making the changes. I know you didn't make your mods and run to the nearest dyno but how much hp or torque do you think you got from your mod and how much do you have in it.
What would you do or have done?
How much in material cost? I don't pay myself
How much power do you think you got from it?
93 7,3 n/a e40d
93 7,3 n/a e40d
It all depends on what you want to end up with, You can spend a couple hundred on decent exhaust. You can do some air mods, basically free. Turn up the pump, again free.
Or you can spend as much as you want, 6 grand, 8 grand, it just depends on what you want, and what you want to do with it.
I want to spend as little as possible. I agree air mods are cheap and have already been planning mine. As to the others. I'm not going to spend thousands. Maybe a couple hundred. Some of these guys think of some really good way to make mods without going out and paying a box chain to install something.
Most of the 200 dollar turbo's I have heard of, is just that. It is usually been a stroke turbo or something else not designed for these engines with none of the associated parts.
I'm sure there are some exceptions and some deals out there.
I would like to try one of the type four cams to lower the peak rpm's, I think I would like it for my use.
Starmilt what do you mean:
I would like to try one of the type four cams to lower the peak rpm's, I think I would like it for my use.[/quote]
What do you do with your truck?
What does lowering the rpm's do? Do you mean it reaches peak torque at a lower rpm?
I pull a small skid steer with mine. It also has a utility bed and loaded with all the tools it weights over 7,000 all by its self. That's why I would like a little more power.
I don't have one, but they are supposed to lower the peak torque about 200 rpm's.
I don't pull or load mine too hard anymore, I use a semi if I need to haul much, so mine is basically a toy now. I will eventually find a deal on a cabover camper one of these days and leave it hooked to a boat. When I do go out on trails I do a lot of idling around, one of the reasons I think the cam would better suit me. I also have a five speed that I intend to put in if the present clutch ever get's bad which will give me double over, so again I think the cam would suit me.
