Installed new Rear Hatch Lift Struts
I got tired of the rear hatch falling down and hitting my head so I replaced them with new 2x4 version. Big difference, goes up much easier and is about 2" higher then the 4x4 version. A 5'5" wife will still be able to close the hatch, EX sitting at the stock height.
Installation tips: (1) Set the clips up on the new struts before starting the job. Do not take the little metal clip all the way off, just move them towards the end into the slot. (2) You will have to remove both struts to get the hatch up high enough to install the new struts.
Note: One strut will not hold the hatch up, doh
Just did mine this past week, used the 2WD version on my 2000 Ex 4x4. Hatch lifts higher (yay!) but still in reach for 5'9" me. Bought the struts here: Lift Supports
For about $20 each. As noted, you have to take both struts off before you can lift the hatch high enough to put the new ones on, and that thing is HEAVY. I propped it up with a 2x4.
Bought the 2WD versions from NAPA. Don't remember the price but they weren't that much. The increased travel is a big plus. I highly advise it.
The process isn't difficult though I did have to bang a bit on the new ones to get them on even with the clip pulled back. This may just be a factor with the NAPA models as the OEM weren't hard to remove. The job can be done by one person but adding a helper to hold the hatch open makes things much easier.
You'll need a thin flat head screwdriver to slide the locking clips back. Otherwise no tools required.
Dragging up an old thread... I used Lou's High Quality Automotive | Marine | Industrial Lift Supports for new struts for the 1.5" additional in the back and new struts for the hood. What a GREAT upgrade for $60. Got them through his eBay store.
Highly recommend!!
Highly recommend!!
