Tranny and driveshaft?
Old 11-28-2011, 09:02 PM
Alaska-Niekamp's Avatar
Alaska-Niekamp
Alaska-Niekamp is offline
This is my situation. The point where the driveshaft goes into the transmission is slightly loose. You can wiggle it a little with your hand. When I hit about 55-60mph it vibrates some. What is the cause of this and does it take a lot to fix cost wise? Thanks.
Old 11-28-2011, 09:11 PM
Ford_Six's Avatar
Ford_Six
Ford_Six is offline
Depends on the setup. I had a C4 automatic with a fixed yoke that kept coming loose, it would also pour oil out the rear when parked facing uphill. I eventually sealed in behind the nut with RTV and used Locktite on the threads to keep it from coming loose again.
If yours has a bolt-on yoke, once you pull the driveshaft pull the nut off and RTV behind it to prevent leaks, then tighten the nut to about 95-100ft/lbs, and it should be good to go. If it's a slip yoke, then you'll likely have to replace the output bushing that the driveshaft rides in, I'm not sure how much that costs though.
Oldguyfl
09-01-2017 08:43 AM
nmclea02
11-13-2010 01:38 AM
joegomez1965
03-05-2007 07:05 PM
jbomb
01-22-2006 09:20 PM
skybob
10-17-2004 05:19 PM
Quick Reply: Tranny and driveshaft?
