at full turn why do i feel a popping and...
Old 11-28-2011, 08:17 AM
patrick1989's Avatar
patrick1989
patrick1989 is offline
patrick1989 is starting off with a positive reputation.
I replaced my shocks thinkin that it was the origional ones makin a bunch of noise and then found out my sway bar links were bad then replaced em now I notice a popping noise at full turn as well as a knocking noise when I hit a bump it sounds like its somewhere in the steering linkage
Could the popping be my ball joints??
Old 11-28-2011, 11:51 AM
dagren99
dagren99 is offline
dagren99 is gaining momentum as a positive member of FTE.dagren99 is gaining momentum as a positive member of FTE.
Check your balljoints and hubs for play. Also look the whole steering linkage over and make sure all is good and solid. May help to get the front off the ground and check the whole front suspension for movement. Not unheard of to break things and then only hear noises under certain conditions.
Old 11-28-2011, 12:09 PM
JOHN2001's Avatar
JOHN2001
JOHN2001 is online now
JOHN2001 has much to be proud ofJOHN2001 has much to be proud ofJOHN2001 has much to be proud ofJOHN2001 has much to be proud ofJOHN2001 has much to be proud ofJOHN2001 has much to be proud ofJOHN2001 has much to be proud ofJOHN2001 has much to be proud of
Sticking hub not disengaging, if its the same feeling when 4wd is locked in
Old 11-28-2011, 12:49 PM
SARDiverDan's Avatar
SARDiverDan
SARDiverDan is offline
SARDiverDan has a very good reputation on FTE.SARDiverDan has a very good reputation on FTE.SARDiverDan has a very good reputation on FTE.SARDiverDan has a very good reputation on FTE.
Mine did the same thing and when I backed up it would make the same noise. Come to find out my U-joints were cracked.
Old 11-28-2011, 01:13 PM
SteveH-CO
SteveH-CO is offline
SteveH-CO has a good reputation on FTE.SteveH-CO has a good reputation on FTE.SteveH-CO has a good reputation on FTE.
I, too, vote for a factory hub that failed to unlock.
Old 11-29-2011, 10:14 AM
Firefighter 1406's Avatar
Firefighter 1406
Firefighter 1406 is offline
Firefighter 1406 has a great reputation on FTE.Firefighter 1406 has a great reputation on FTE.Firefighter 1406 has a great reputation on FTE.Firefighter 1406 has a great reputation on FTE.Firefighter 1406 has a great reputation on FTE.
I agree, just did my dads truck, has a popping noise when driving. Hubs were fine but wheel bearing and front joints were TOTALLY shot.
Old 11-29-2011, 10:34 AM
patrick1989
when I had my truck on the rack changing shocks I yanked on the wheels and they were fine I'm beginning to think its my steering linkage is starting tko wear down
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
