bad belt, and chirp noise
Old 11-28-2011, 06:47 AM
tjc transport's Avatar
tjc transport
tjc transport is offline
i ain't rite
tjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputation
i developed a chirp in my 02. the belt is getting replaced because it is starting to show wear and has been on the engine for close to 40,000 miles.
the engine itself has 180k on it. ithe top idler has belt rubber stuck to it. does this sound like it is the top idler that is making the noise?
Old 11-28-2011, 10:32 AM
Brother Les's Avatar
Brother Les
Brother Les is offline
Brother Les is a splendid one to beholdBrother Les is a splendid one to beholdBrother Les is a splendid one to beholdBrother Les is a splendid one to beholdBrother Les is a splendid one to beholdBrother Les is a splendid one to beholdBrother Les is a splendid one to behold
120,000 on same belt... no wear and no noise......
something is out of alignment or bearings wearing on yours.
Old 11-28-2011, 10:37 AM
snakedoc's Avatar
snakedoc
snakedoc is offline
snakedoc is a splendid one to beholdsnakedoc is a splendid one to beholdsnakedoc is a splendid one to beholdsnakedoc is a splendid one to beholdsnakedoc is a splendid one to beholdsnakedoc is a splendid one to beholdsnakedoc is a splendid one to behold
i would check the idler pulley barrings.
Old 11-28-2011, 11:15 AM
tjc transport
i ain't rite
well, i just got done. belt was wasted. the top idler bearing was in iffy condition, so that got changed. the tensioner pulleys don't look that hot, so i will have to keep an eye on them. i would have changed them too, but they are on back order.
Old 11-28-2011, 04:44 PM
CAPTAIN DIESEL
CAPTAIN DIESEL is offline
CAPTAIN DIESEL is starting off with a positive reputation.
check pully bearings
Old 11-28-2011, 05:13 PM
Shake-N-Bake's Avatar
Shake-N-Bake
Shake-N-Bake is offline
Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.
Usually when the belt is trashed it ends up being the tensioner assembly (at least that's how it's worked out for me so far...)
Ok...I have to ask.....so how did you end up with a $0.47 cent mod? Did you find 3 pennies under the valve covers?
Old 11-28-2011, 05:15 PM
brian42's Avatar
brian42
brian42 is offline
brian42 has a brilliant futurebrian42 has a brilliant futurebrian42 has a brilliant futurebrian42 has a brilliant futurebrian42 has a brilliant futurebrian42 has a brilliant futurebrian42 has a brilliant futurebrian42 has a brilliant futurebrian42 has a brilliant futurebrian42 has a brilliant futurebrian42 has a brilliant future
I recently replaced my belt (200K on the engine and at least 60K on the belt). I replaced the upper and lower idlers (I have dual alternators) as well as the tensioner. I had a small noise before I replaced the belt and it went away when I did the changeout so I don't know which was the culprit.
Also, I switched to a Goodyear Gatorback belt and love it!
Old 11-28-2011, 05:16 PM
snakedoc's Avatar
snakedoc
snakedoc is offline
it could be like mine i used a 0.03 washer on it.
Old 11-28-2011, 05:18 PM
lhud
lhud is offline
lhud has a good reputation on FTE.lhud has a good reputation on FTE.
Hey, just another suggestion: with the belt off don't overlook checking all the pulleys including the power steering. The bearings in the idler pulleys can easily be punched out and new bearings installed. I simply purchased a set of new pulleys, installed them and then on rainy days replaced the bearings in the used pulleys - each cost approx. $7 bucks +/-.
Old 11-28-2011, 06:04 PM
tjc transport
i ain't rite
well, i know it is not the alternator, water pump, or ac compressor, since they are all less than 5 months old.
and i doubt it is the power steering, because the sound does not change when i turn the wheel loading the pump.
the tensioner pulleys are tight, just need a good cleaning of belt rubber on the roller surfaces.
the idler pulley bearing was sloppy, that is why i think it was the culprit.
LonnieD
08-06-2013 02:15 PM
Fox Fader
1968-2013 Full Size Vans
04-06-2010 10:26 PM
whitesmoke
08-25-2005 12:39 AM
sselkirk
Modular V8 (4.6L, 5.4L)
04-19-2004 03:03 PM
Ryan50hrl
19
09-22-2003 08:14 AM
Quick Reply: bad belt, and chirp noise
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
