69 F350 Bump Side Crew Cab Restoration
#46
i'm running a 50 in my excursion (7.3) and it is a 44 with a bigger set of axles 44's are tuff if gets and after market long axle, replace it and they are a hard nut to crack ..just make sure and keep and eye on the bushings on the dodge front end and you wont get a death wobble there is where the problem is. other than that it should make you a good runner need to bush them bout 90k or so most often and they are good to go.
#48
I guess you are referring to the consumbables being expensive. I've failed to find anything cheap thus far. It is not a poor man's endeavor. I'm gonna have to go slow and part out a few things and sell another project to even get started good.
Another question would be, how much bigger is a superduty chasis than the 69 crew cab chasis. Would there be any hope of making it fit or should i keep looking for 97 back?
total spent so far!!!!
69 Crew Cab and Donor 72 F-250 1300
91 D350 w/12 Valve and a518 800
241dhd Tansfer case 200
total 2300
Yet to spend :
4x4 OD section for a518 400
Front end for 69 650
Motor mounts 160
Fab Work 300
Sandblasting 700
POR 15 Frame 150
Bed for 69 500
total 2860
Other Miscellanous will be 2000 Plus the paint job! Wait, i can't afford at all Anyone want to buy my project!!!!!!!!!!!! Just kidding. Gonna have to take my time.
#49
#50
Yeah i know. I'm wanting to take my time and do it right. I've had some fixer upers but never really went all the way. The only thing i have brought back to a "new" condition is a 1975 Starcraft 18' Supersport aluminum boat. We did it as a family and there's not one like it on the water. I spent 3500 in the process, but a new one like it is in the 20K range.
#51
99 Superduty Front and rear differential
I got a call from a guy responding to a WTB CL add today on the front and rear differential. He has a set of front and rear diff's for a 99 super-duty (4 wheel disc brakes) that i can pick up for 600. I don't have the case on hand, but will get it if they will work. I know the wheels for the newer set up are more expensive, but it is a low mileage bargain. What say you?
#52
#53
#55
Dude Backed out
Bummer, dude backed out on the sale. His 6.0 bit the dust and he decided to keep the 95. It was a great price and a great truck. THE SEARCH CONTINUES
#58
Dana 50 Front end
The guy that i spoke with on the 99 SD front end called me back today. He needs to move the axles. The part # indicates a dana 50. It is what i have on my F250 SD Crew Cab. I've had no problem with it. I know the bearing are outrageous, but is there any other reason to stay away from the 50's. I can get the front and rear for 600 complete with hubs???
#60
Maybe i'm beating my head against the wall for nothing, but i just keep looking around. I know if i just buy the axles i'll have to look for the hardware, springs then all of the brake line stuff as well. I'm looking real hard at a super duty frame (f350 4x4) with all of that with it for around 1300. Its just about 6 hours away. I'll eventually find what i want and get to work. I really need to sell some junk first
