Finding a zf tranny
For which engine--300-351w or 460?
Application info here, easier to post this than to copy or type it out:
Domestic Truck Tranny Guide
You have to scroll down quite a ways....
If your truck is like mine (2wd), you will need a new hydraulic hose, a 5-speed crossmember and support brackets, a new driveshaft, a new transmission tunnel cover that goes in the cab floor, and you'll have to fabricate a way to mount the shift boot. I also installed a new slave cylinder (Ford part is the best route) and a new speedometer gear (until I changed the drive gear on the output shaft).
Just want to add that the diesel ZF's have a separate bellhousing, so they won't match up. Might be useful for someone that finds this thread while searching.
Also, the ZF's found on F-superduty (F-450) 2wd trucks are actually 4wd ZF's with driveline brakes instead of transfer cases.
Correct, but the bell is not "separate" from the trans, it's that it has a different pattern. All ZFs are integral bells.
So there is small block gas, big block gas, and diesel. Each could be either 2wd or 4wd depending on the tailhousing.
monkei
17
12-05-2009 07:10 PM
wheelhoppin67
02-10-2005 10:30 AM
tampabandit
04-18-2004 01:55 AM
