its cold outside.is your fuel economy taking a nasty hit? the cause may be more than winter fuel - Page 5 - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
Reload this Page >
  #61
Old 11-21-2012, 09:51 PM
'94IDITurbo7.3's Avatar
'94IDITurbo7.3
'94IDITurbo7.3 is offline
'94IDITurbo7.3 is gaining momentum as a positive member of FTE.
Originally Posted by 1989f250IDI View Post
How do you install an aftermarket gauge? I have one for a gas but id have to see what the temp sweep is. What's a good range for our engines
https://www.ford-trucks.com/forums/1...-in-6-9-a.html
  #62
Old 11-21-2012, 09:58 PM
kobaltblue's Avatar
kobaltblue
kobaltblue is offline
kobaltblue is gaining momentum as a positive member of FTE.
Thanks! I'v been chewing at the bit all pissed off wondering what the hell happened to my MPG's over the last week down to 17 on the highway was even thinking of slowing down (Like that would happen ) I did notice a little more EGT's on long up hill runs.
  #63
Old 11-21-2012, 10:18 PM
'94IDITurbo7.3
this is what i have just i got he black face one. works great!
Buy Sunpro Style Line Mechanical Water/Oil Temperature Gauge - White CP8207 at Advance Auto Parts
  #64
Old 11-21-2012, 11:29 PM
Greg5OH
Greg5OH is offline
Greg5OH is starting off with a positive reputation.
Originally Posted by Marianna2003 View Post
You should check the Watt rating of your block heaters. Around here we're paying $0.12/KWH. That's 1000W for 1 hour for $0.12. Our heaters are ~1000W so we should be able to plug in for 8 hours for a buck or about a ~¼Gal of fuel.
how much do our trucks use on high idle in the mornings? takes 10-15 mins for high idle to kick off usually, think it would use a 1/4 gallon over that time?
  #65
Old 11-22-2012, 01:41 AM
maverick1701's Avatar
maverick1701
maverick1701 is offline
maverick1701 has a good reputation on FTE.maverick1701 has a good reputation on FTE.
since he mentioned cold weather tips.....for you guys up north who need to heat up transmissions before driving (when it's REALLY cold) an easy trick is to put truck in gear and the x-fer case in neutral while you let the truck idle and warm up....it warms up the trans and you are good to go when you hop in.
  #66
Old 11-22-2012, 10:08 AM
jayro88
jayro88 is offline
jayro88 is gaining momentum as a positive member of FTE.
Originally Posted by '94IDITurbo7.3 View Post
yep, you can thank extended idle times and winter blend for that low mpg. i usually don't even check my mpg during the winter/cold months.
That combined with a c6, my 120K mile IP/injectors and my van having the aerodynamics of a barn. My only plus is that I have 3.54's instead of 4.10's
  #67
Old 11-22-2012, 10:17 AM
'94IDITurbo7.3
oh wow! hahaha
  #68
Old 11-22-2012, 11:00 AM
84-6.9L's Avatar
84-6.9L
84-6.9L is offline
84-6.9L is gaining momentum as a positive member of FTE.84-6.9L is gaining momentum as a positive member of FTE.
True it will work, however fords pump fluid in park, and this can only be safely done in a manual, that auto is going to make some noise when you try to put er' back in park to get that t-case into gear.
  #69
Old 11-22-2012, 11:41 AM
Bob_Smith's Avatar
Bob_Smith
Bob_Smith is offline
Bob_Smith is starting off with a positive reputation.
I own the CP8207, they didn't have the black one when I went to get one. Had it for over 5 months now, and it's still goin strong. Not bad for less than $16 out the door at my local AA. With the included light it's plenty easy to see at night.
  #70
Old 11-22-2012, 08:19 PM
maverick1701
good call....I forgot to specify...manual trans
98x50
6.7L Power Stroke Diesel
11-19-2015 05:57 AM
Jimax
25
10-16-2012 11:26 AM
Aaron-71
62
07-11-2011 05:05 PM
FORDF250HDXLT
06-18-2010 10:52 AM
ernesteugene
46
06-29-2007 12:21 AM
Quick Reply: its cold outside.is your fuel economy taking a nasty hit? the cause may be more than winter fuel
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
