its cold outside.is your fuel economy taking a nasty hit? the cause may be more than winter fuel - Page 4 - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
Reload this Page >
  #46
Old 12-28-2011, 07:08 PM
IDIDieselJohn's Avatar
IDIDieselJohn
IDIDieselJohn is offline
IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.
How about 3 of 'em?
  #47
Old 12-29-2011, 11:55 AM
finitetime
finitetime is offline
finitetime is starting off with a positive reputation.
3 of them OUCH!! I'm with ford250. I have a list of need to do, should do, and gonna have to do, on one. If I had 3 I would sell the others to buy parts for the one I kept.
  #48
Old 01-12-2012, 12:34 PM
Coccyx
Coccyx is offline
Coccyx is starting off with a positive reputation.
Use a timer on your extension cord. Have it kick in 2 hours before you plan to start the rig... save the unnecessary extra 8+ hours of block heater time.
  #49
Old 01-12-2012, 12:39 PM
Onus's Avatar
Onus
Onus is offline
Onus is gaining momentum as a positive member of FTE.
When it real cold the block heater has to be in for over six hours to start with no fast idle. 2 hours does nothing here when its cold and it still kinda rattly on startup.
  #50
Old 01-12-2012, 12:42 PM
IDIDieselJohn
On my 7.3 I have a tank heater (heater you plumb into the heater lines) + the block heater.
2 hours, it would fire right up like in the middle of summer, no fast idle, and have heat in the cab right away
  #51
Old 01-13-2012, 11:12 AM
Onus's Avatar
Onus
Onus is offline
Sounds like i need an additional heater!
  #52
Old 01-13-2012, 05:31 PM
ihateminimumwage's Avatar
ihateminimumwage
ihateminimumwage is offline
ihateminimumwage has a very good reputation on FTE.ihateminimumwage has a very good reputation on FTE.ihateminimumwage has a very good reputation on FTE.
Sounds like yours is the way mine is. Brand new replacement block heater from Napa, and even with it plugged in for a couple of hours it takes 10 minutes for the truck to kick into low idle (around 1-5 degrees out at 7am recently)
I know the wiring in my apartment is crap and isn't helping any. Been debating on just leaving it plugged in overnight. Might just using a different outlet, since I've been using the kitchen one that has a fuse since my last rotten block heater cord caught fire...
  #53
Old 11-21-2012, 08:03 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
FORDF250HDXLT is online now
FORDF250HDXLT has a superb reputationFORDF250HDXLT has a superb reputationFORDF250HDXLT has a superb reputationFORDF250HDXLT has a superb reputationFORDF250HDXLT has a superb reputationFORDF250HDXLT has a superb reputationFORDF250HDXLT has a superb reputationFORDF250HDXLT has a superb reputationFORDF250HDXLT has a superb reputationFORDF250HDXLT has a superb reputationFORDF250HDXLT has a superb reputation
bump.it's that time of year again guys.
  #54
Old 11-21-2012, 08:06 PM
IDIDieselJohn
Yep, winter fuel, my long warm ups (I always wait till the high idle kicks off before taking off).
Oh well, all gonna be over in a week when my van goes for storage, then once again, I'll be IDIless for winter.
  #55
Old 11-21-2012, 08:48 PM
1989f250IDI's Avatar
1989f250IDI
1989f250IDI is offline
1989f250IDI is starting off with a positive reputation.
What's wrong with our stock temp gauges?
  #56
Old 11-21-2012, 09:10 PM
'94IDITurbo7.3's Avatar
'94IDITurbo7.3
'94IDITurbo7.3 is offline
'94IDITurbo7.3 is gaining momentum as a positive member of FTE.
they are inaccurate as all get out. my stock gauge hardly gets to the n on normal but my real temp gauge shows right at 190.
  #57
Old 11-21-2012, 09:12 PM
'94IDITurbo7.3
winter blend fuel.......
  #58
Old 11-21-2012, 09:23 PM
1989f250IDI
How do you install an aftermarket gauge? I have one for a gas but id have to see what the temp sweep is. What's a good range for our engines
  #59
Old 11-21-2012, 09:37 PM
jayro88
jayro88 is offline
jayro88 is gaining momentum as a positive member of FTE.
I've noticed my MPG has dropped into the 13.xx range with the cold weather. Of course I usually let it idle for about 10 minutes in the morning to melt the ice.
Just in time for diesel prices to jump too. Went from 3.91 to 4.25 a gallon in about 4 days.....GRRRRR. Hopefully it will come down after Thanksgiving.
  #60
Old 11-21-2012, 09:41 PM
'94IDITurbo7.3
yep, you can thank extended idle times and winter blend for that low mpg. i usually don't even check my mpg during the winter/cold months.
Quick Reply: its cold outside.is your fuel economy taking a nasty hit? the cause may be more than winter fuel
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
