ecoboost air ride
Old 11-27-2011, 12:43 PM
sidrush's Avatar
sidrush
sidrush is offline
ecoboost air ride
i just traded my 2004 lincoln navigator for a 2011 ecoboost supercrew 4x4 6.5 trailer tow option. on my lincoln it had a full air ride. the nav sat low until you put it in 4x4 then it lifted 2to 3 inches . that is the only thing i miss about my nav. i was wondering if any one has tried to do a airbag kit at all 4 corners ? and if there would be any mpg increase in lowering the truck like this ?
Old 11-27-2011, 07:06 PM
scuby22's Avatar
scuby22
scuby22 is offline
I had the same thought after I purchased my truck. I have approx. 3in. of clearance to get in to my garage and I would like to put a slightly larger wheel/tire combo on it.
I found this webpage and it appears they have airbags for all four corners. If you scroll to the bottom, there's an image that has the same connections as our front shocks. The only difference is there is an air bag on it. You would no longer use the stock springs.
Any other suggestions?
Air Struts
Old 11-30-2011, 07:56 PM
Brandon150's Avatar
Brandon150
Brandon150 is offline
Can somebody explain how to get to the ecoboost section? I've been given the hyperlink twice now but that doesn't help for long.
So for example is it under the models drop down>f150>2009+f150??????????
Old 11-30-2011, 08:41 PM
scuby22's Avatar
scuby22
scuby22 is offline
Scroll down past the engines forum.
It's under performance, engine, and troubleshooting..
Old 11-30-2011, 10:13 PM
Brandon150's Avatar
Brandon150
hmmm... sorry but MORE DETAIL PLEASE. Scroll down? Huh? Down where? Why is it so hard to find such a high profile motor!
Thanks for the help
J ballan
10-20-2015 07:26 PM
parshdude
1999 to 2016 Super Duty
10-02-2013 09:46 PM
Waynenap
11-22-2010 07:54 PM
LOOnatic
04-28-2004 12:15 PM
Quick Reply: ecoboost air ride
